Proper Comm Lathe Motor
- jeekelemental
- Has thanked: 39 times
- Been thanked: 12 times
Hi guys, I'm going to use the Trinity comm lathe bought months ago and I need to know wich is the proper motor to use in. It came with a Fantom stock motor but I would like to know if a silver can will do the job or if it's better to keep the Fantom. Thanks in advance.
"Flagellum Dei"
Powered by Flux Capacitor
- juicedcoupe
- Has thanked: 268 times
- Been thanked: 2094 times
Re: Proper Comm Lathe Motor
My lathe came with a stock 550, which is slower than a 540 silver can. Even then, it works best if I slow it down. I suspect that a cheap crawler motor would work well.
- jeekelemental
Sounds interesting, maybe it is the time to give to my Integy 55T a second chance.
"Flagellum Dei"
- juicedcoupe
Back in the day, I believe that most people used 4 cell packs on their lathes as well.
- juicedcoupe
Variable speed is nice. If you have a servo tester and spare esc, it makes it easy.
Just plug it into the tester's outlet port and setup the esc as usual. An older esc with adjustments is a little easier than push button models but none of them are hard.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Stock motor and 4 cell is what we used....
- 1013 Views
Last post by tamiya
- 1925 Views
Last post by Lonestar
- 1677 Views
Last post by Hotrodvw
- 2193 Views
Last post by mrlexan
- 523 Views
- 2793 Views
- 21 Replies
- 2759 Views
Last post by joel45acp
- 822 Views
Last post by slotcarrod
