Hey all,
I am fitting one of my cars with rc10b4 caster blocks. I drilled out the caster block and the original pins work on that. Now I am looking at how the steering block is attached and I need a kingpin.
When I look at the instructions the part number is 9622 for the associated pins. They are skinnier than the older rc10 pins. I found the length in another post here of .915" What diameter are they? How are they secured? They don't seem to be grooved or threaded. I looked up the manual and it seems that they are secure by friction and hope.
Is there an inexpensive source for them?
b4/t4 kingpins
- Has thanked: 1243 times
- Been thanked: 639 times
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: b4/t4 kingpins
They are held in by small 2-56 button head screws which screw into a small hole parallel to the the hinge pin. The screw head prevents them from coming out. The hinge pins are a smaller diameter so they won't fit into an older car.
Re: b4/t4 kingpins
Ah So I will also need some of these 2-56 button screws to make this work. the screw head being a retainer makes sense.
- 601 Views
Last post by askbob
Users browsing this forum: Frankentruck,
Google Feedfetcher and 14 guests
