Odd generic aluminum shock binding issue
Forum rules
- Been thanked: 325 times
I've had good luck with these generic aluminum oil-filled shocks, for the most part...they're made by dozens of different clone companies so I don't think brand really plays a part in this particular issue. In fact, I just used 2 sets of these for my Marui Shogun resto-mod and they work great. However, I'm having a weird issue with 2 different sets of these with the WLToys 144001 car I'm building for my daughter. This project will run either an on-road body or an offroad body, and to make the suspension change easier (and because a second set of shocks is so inexpensive), I had planned to have one set of stiffer shocks for on-road, and a second set with better damping for offroad.
The original shocks do something strange. If left to rest for a while, they bind for the first bit of the compression, then they will work fine. If you let the car sit for another while--not even long, like a half hour perhaps--they bind again. I was planning to remove the shocks and re-test with them off the car, but that test was confirmed with the second set of shocks. Right out of the package, they similarly bind a bit right at the beginning of the compression phase. It's quite unusual.
Have any of you experienced this? I'm thinking to reduce the shock travel by a few millimeters by adding a spacer inside the shock and see if that resolves the binding. Ideas?
- Has thanked: 1243 times
- Been thanked: 639 times
Re: Odd generic aluminum shock binding issue
Sounds like they are getting hung up in the shock body in a specific spot. Once they start moving get they past the hang and keep loose.Have you taken the shock apart yet?Coelacanth wrote: ↑Fri Aug 27, 2021 1:26 pm I've had good luck with these generic aluminum oil-filled shocks, for the most part...they're made by dozens of different clone companies so I don't think brand really plays a part in this particular issue. In fact, I just used 2 sets of these for my Marui Shogun resto-mod and they work great. However, I'm having a weird issue with 2 different sets of these with the WLToys 144001 car I'm building for my daughter. This project will run either an on-road body or an offroad body, and to make the suspension change easier (and because a second set of shocks is so inexpensive), I had planned to have one set of stiffer shocks for on-road, and a second set with better damping for offroad.
The original ones were completely rebuilt with different oil weight than what they came with, but that didn't resolve the issue. I haven't disassembled the second set but I expect they will be no different. I might get around to doing some troubleshooting this weekend. It doesnt seem to be a matter of them binding at a specific point, as the issue goes away for a while and they work perfectly fine after they "break loose", but leave them alone for awhile and the problem repeats and they get stuck again.
If rebuilding the second set doesn't correct the problem, I'll limit the piston travel by a few millimeters and report back if that helped.
- Has thanked: 2759 times
- Been thanked: 2250 times
Sounds like "striction" caused by wrong lube in the O rings , get some Team Associated green slime , I've used it on those shocks and it works .
Good idea. I see that often being recommended on this forum to lube shocks, even for shelf queens. I never had a use for it before now, at least never with Kyosho Golds...
My LHS has a few tubes, I'll pick one up after work this afternoon and report back.
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
This is what I use.
https://www.amainhobbies.com/protek-rc-premier-blue-oring-grease-multipurpose-lubricant-10ml-ptk-1410/p-qeawqseqpzqxactz
My LHS has it as well.
- MarkyDents
- Has thanked: 1809 times
- Been thanked: 643 times
Absolutely the best, been using it as long as I can remember.
Hey Cru ! Go balls out
Update on the shock binding issue and AE Green Slime...my shocks got slimed!
I took the new set, which needed to be fully disassembled anyway as they had very little oil inside them, and dabbed a tiny bit of Slime on the shafts and O-rings, as these shocks have removable bottom caps making that very easy. Testing the piston compressions, it looked like there was no more of that initial friction, and I reassembled the shocks with the heavier oil weight that I needed. The suspension now has smooth compression, so thanks for the suggestion, guys!
I'll rebuild the 4 original shocks next, the issue with those is even worse, but I expect will also be resolved.
Share and enjoy
- 1515 Views
Last post by Chickenpuff
- 1030 Views
Last post by sgirouard
- 2082 Views
Last post by necka
- 1434 Views
Last post by Bongo Fury
- 849 Views
Last post by jcwrks
- 1078 Views
Last post by bearrickster
- 3329 Views
Last post by Haggy38
- 1697 Views
