Kyosho Scorpion spare parts.
JonasCallmin
Post by JonasCallmin »
Hi.
I need some help to find a spare part to my Kyosho Scorpion from 1982.
In the building manual its referd as : 87.7.10160 and is a pinion gear with 10 theth and outer diameter of aprox 12mm with a center hole of 4mm.
I have serched the internet with no luck.
Jonas Callmin
Dadio
Has thanked: 2759 times
Been thanked: 2250 times
Re: Kyosho Scorpion spare parts.
Post by Dadio »
The inner hole will be 3.17 mm , that should help as its a standard pinion size and its a 10 tooth , the only thing i cant help with is the gear pitch , its probably 0.8 mod so try searching ebay for 10 tooth 0.8 mod pinion and there should be a ton of hits , hopefully someone can chime in if its not 0.8 mod .
JonasCallmin
I messured the axle shaft to 3.97mm so 4 mm it is.
I have 2 old Scorpions and this is the part that have the most were and tear so i think i cant be the only one with this problem.
Has thanked: 269 times
Been thanked: 2094 times
Makes me wonder if the entire gearbox from a re-re will swap in.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Dadio wrote: Sat Aug 14, 2021 6:45 am The inner hole will be 3.17 mm , that should help as its a standard pinion size and its a 10 tooth , the only thing i cant help with is the gear pitch , its probably 0.8 mod so try searching ebay for 10 tooth 0.8 mod pinion and there should be a ton of hits , hopefully someone can chime in if its not 0.8 mod .
Original Scorpion gears were Mod 1.
Jonas, are you looking for the the top shaft gear inside the trans?
Edit: had to do a quick double check of the manual. The top shaft/final pinion gear is part number SC-83 and there's some on eBay(not my auction): https://www.ebay.com/itm/112085974525?hash=item1a18d83dfd:g:U8AAAMXQDnpTXFPe
Dadio
Post by Dadio »
Sorry if I confused the issue , commonly the gear on the motor is referred to as the pinion :oops:
JonasCallmin
Thank you!
I will go for the E-bay option. From what I can see it looks exactly the same :D
My instruction manual don't have the number you refered to thou, but mine is a Swedish translation so maybe diffrent countries have diffrent systems?
Thank you all for the support.
Return to “Kyosho Forum”
