Cobra 'Battery Bug'... anyone have specs?
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
Going through my stash for the first time in a long while, I found three of these things that I used back in the day. IIRC, they supposedly bring a used NiCd pack down to a safe level for recharging after use, or leaving it on for storage so the battery doesn't develop the dreaded 'memory'. I believe you could also fully peak a pack then plug in the Bug for a maintenance discharge cycle to condition the pack... or something. I don't recall specifics. Anyone have the instructions or know any intimate details about these things, what they did and how they did it?
I have two barely-used Onyx 1800 NiCd packs that will see very infrequent use. Any reason not to use these things on them for giggles and why-nots?
I'm tempted to chip all the plasti-dip off one and see what makes them tick.
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Re: Cobra 'Battery Bug'... anyone have specs?
I remember those. Mine were called Bulldogs but I'm sure they were the same. I have about a dozen, some red and some green. Give me a few minutes and I see if I can locate the instructions. Be right back...
Edit,
Here they are. I forgot I had blue ones as well.
I've told y'all, I never throw anything away.
Hmmm, it appears the company was located in Beaverton, OR. There's something about that name that makes me chuckle.
Edit,
- Bottom Feeder
- XLR8
You're very welcome.
It's very clear these things were molding from epoxy using ice cube trays.
I have a couple that are cracked probably from the intense heat.
- Has thanked: 1129 times
- Been thanked: 3919 times
3645 Hall Blvd was Tammies Hobbies old location. I was hired as they were moving to their current location. They made a pretty famous line of chargers called “Lightning Bolt”. Being just up the road I bet they were part of Tammies.
- 2071 Views
Last post by SoloGraphix
- 5227 Views
Last post by mk-Zero
- 1374 Views
Last post by Diamond Dave
- 3752 Views
Last post by Lonestar
- 917 Views
- 1199 Views
Last post by USA-1
- 2747 Views
Last post by Drusky
- 643 Views
Last post by civilguy
