Hi guys. i strill run my team truck and enjoy racing it against more moderns stuff occasionally.
anyway, i worked out a setup that seemed to work for me , that may work for you:
blue springs on the front, 35 wt oil, number 2 piston, arms level. shock on the outer hole on the shock tower
green springs on the rear, 27.5 wt oil, number 1 piston, arms level, shock on the middle on the arm and middle on shock tower
long wheelbase, -1 degree camber all round.
1 degree toe out on the front. 3 degree toe in at the rear
shorty lipo pushed to the front of the cup with 40g of weight either side of the lipo.
jconcepts swaggers (pink) on the front, schumacher minispike (yellow) on the rear
8.5t motor, running a b4 layshaft conversion (schelle racing 3 pad slipper)
i found thid setuop gives plenty of stering when needed , but also the bumnp steer of the truck also allows it to push slightly at higher speeds (the wheel waggle like hell !)
maybe worth a shot at your local club?
RC10T setup for UK astro turf
- 1187 Views
Last post by Medved
- 1291 Views
Last post by kaiser
- 2119 Views
Last post by Lonestar
- 1411 Views
- 1900 Views
Last post by DaveM
- 2950 Views
Last post by tecnica2001
- 867 Views
Last post by RogueIV
- 1330 Views
