Very young youngtimer ;) Hot Bodies D413
Forum rules
Trass
Has thanked: 487 times
Been thanked: 258 times
Post by Trass »
Hi,
This is my refurb of an used Hot Bodies D413.
It came with a lot of used parts en some parts ready to go to the trash...
My goal is toi make it as i want it on myshelf ;)
- new parts
- removing of anodising
- polishing of alloy parts
- change all screws by some Inox A2 version.
When i disassembled the chassis, i found a lot of used parts has not shown on pictures before i bought it... :evil: :evil: :evil: . I wasn't happy !!!
A lot of cash after, parts are at home and i start to refurb this kit...
The seller said :i run it all week-ends since a long time and i correctly clean it at each time ..."
Look at " corrctly cleaning at each time"
Cleaning from me (just the alloy parts) last friday, and removing of anodising:
Saturday night polishing ;)
re-built of shocks
Jerome
TheDiamondOne
Has thanked: 2077 times
Been thanked: 588 times
Re: Very young youngtimer ;) Hot Bodies D413
Post by TheDiamondOne »
Wow, do you use a tumbler to polish smaller parts! Thats incredible work.
Lots and lots of elbow-grease and sore wrists and hands...either with fine grit wet-sanding or a polishing bit & compound with a Dremel, I'm guessing. :mrgreen: Nice work there.
XLR8
Has thanked: 1684 times
Been thanked: 1180 times
Post by XLR8 »
For polishing metal, I've mounted an 8" buffing wheel in a bench grinder. It can make aluminum appear nearly as reflective as chrome. Here's an aluminum push bar that I've made for the Bronco. The intent was to make the bar shine like the chromed bumper and grille and I think it comes very close.
This method can be very tricky however, especially for small parts. You really need to maintain a firm grip on the part or the grinder will send it flying. When that happens, I can usually find the part protruding from the dry wall immediately behind the grinder or the part is lost forever. :oops: Anyway, it's important to be very careful when using a grinder; wear eye protection etc.
That's a quick way to polish aluminum but there is something very special with hand polishing - it just looks beautiful.
Nice job Jerome! 8)
Trass
Post by Trass »
TheDiamondOne wrote: Sun Apr 18, 2021 5:13 pm Wow, do you use a tumbler to polish smaller parts! Thats incredible work.
Thanks,
No, it's a dream to should be come true... but all the videos i find don't talk about alumnium polishing, just brass.
Not shure about the result
i'm still waiting before buy one
Coelacanth wrote: Mon Apr 19, 2021 1:44 am Lots and lots of elbow-grease and sore wrists and hands...either with fine grit wet-sanding or a polishing bit & compound with a Dremel, I'm guessing. :mrgreen: Nice work there.
Thanks ;)
My fingers hurt me since saturday.
Long time ago, i try a dremel, but the result was some umperfect shape into the part and it was like a grinded looking.
Sometimes, i use fine grit wet-sanding directly wtih Belgom Alu, rarely water.
XLR8 wrote: Mon Apr 19, 2021 12:08 pm For polishing metal, I've mounted an 8" buffing wheel in a bench grinder. It can make aluminum appear nearly as reflective as chrome. Here's an aluminum push bar that I've made for the Bronco. The intent was to make the bar shine like the chromed bumper and grille and I think it comes very close.
Nice job Jerome! 8)
Thank you!
Nice result for your parts, but i can't do the same. Maybe i don't have the good supply to polish as it could be... Obviousely, your are right about the tiny parts ;) dry wall xill love them :roll:
Which polich compound do you use with your grinder?
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Post by RC10resto »
Very nice work!
What did you use to remove the anodizing?
RC10resto wrote: Mon Apr 19, 2021 3:22 pm Very nice work!
Easy Off oven cleaner. Let it soak for a few minutes, brush off with toothbrush and rinse with water. Wear gloves because the oven cleaner will irritate your skin. Sometimes you'll see a dark grey smut appear, I think it depends on the quality of the original anodizing...but that wet-sands off very easily with fine-grit sandpaper (400 or higher).
RC10resto
Post by RC10resto »
Thanks C, that is what I usually use.
Just trying to see what they are using on the other side of the Pond :wink:
XLR8
Post by XLR8 »
Trass wrote: Mon Apr 19, 2021 3:09 pm
Thanks,
Thanks ;)
Nice job Jerome! 8)
Thank you!
Thank you Jerome.
I'm not certain where I bought the polish compound but it might have come from Harbor Freight. I got it a very long time ago, it is almost completely used up and the label is missing. Anyway, it is a round stick form that is applied to the spinning buffing wheel.
For cleaning and maintaining polished metal, I've found that Mothers Mag and Aluminum polish works great.
https://www.amazon.com/Mothers-05101-Mag-Aluminum-Polish/dp/B0009H519Y
Trass
Post by Trass »
Thanks!
I use "Destop" .
I made a post about anodising removing long time ago : https://www.rc10talk.com/viewtopic.php?f=37&t=40691
XLR8 wrote: Tue Apr 20, 2021 12:29 am
Thanks,
Thanks ;)
Nice job Jerome! 8)
Thank you!
Thank you Jerome.
Ok XLR8,
I will learning about compounds to understand how it work, because my tests are not conclusive.
Jérome
Trass
Post by Trass »
some work.
It's time to go seriously
cleaning of the old chassis plate:
Before
after some work :
it's a private joke ;) the old one and the nearly new one ...
re-built :
Jerome
Trass
Post by Trass »
News step
Jerome
KidAgain
Business Member
Has thanked: 513 times
Been thanked: 431 times
Post by KidAgain »
Wow nice build............................
Trass
Post by Trass »
KidAgain wrote: Fri Apr 23, 2021 10:41 am Wow nice build............................
Thank you !
Here is the continuation :
I made a few small deviations from my first directive which is to de-anodize everything, but my fingers have not yet recovered ...
Jérome
Trass
Post by Trass »
today :
Jerome
