Servo Spec Question
Servo Spec Question
I have been looking at small high-speed servos lately to replace some of my older ones and I have a question. Why, in this era of Lipo batteries—which isn’t new, are servo manufacturers still using the 4.8v and 6.0v speed and torque standard? Wouldn’t it be more informative to use 3.7v and 7.4v (and maybe more, like 11.1v)? Anyone who really cares about these numbers is running lipos. Any thoughts?
- juicedcoupe
- Has thanked: 269 times
- Been thanked: 2094 times
Re: Servo Spec Question
Because 4.8-6 volts are still commonly used in BEC'S. NIMH receiver packs are still used as well.
Servos made for high voltage typically have those ratings as well.
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
It also enables you to perform a performance comparison against the older gear.... speed and torque figures at (say) 7.4v are always going to be higher than at 4.8v or 6.0v....
- juicedcoupe
While I absolutely agree with you, its probably fair to say that modern digital servos are going to easily outperform older analog stuff at any voltage.Incredible_Serious wrote: ↑Tue Mar 09, 2021 4:10 pm It also enables you to perform a performance comparison against the older gear.... speed and torque figures at (say) 7.4v are always going to be higher than at 4.8v or 6.0v....
Outside of performance, I think most of the newer stuff is much lower quality than a lot of vintage stuff. I've got 30 year old Futaba analogs that still work perfect, I wouldn't expect that from most of the stuff on the market.
Airtronics servos are still as sharp as ever. Getting hard to find parts for them though. Airtronics 94145 is still the best 1/12 scale servo I have ever used.
- 5696 Views
Last post by R6cowboy
- 708 Views
Last post by jcwrks
- 1573 Views
Last post by Top_Billing
- 3154 Views
Last post by CON2
- 740 Views
Last post by REMJ666
- 1083 Views
Last post by TheDiamondOne
- 906 Views
Last post by SmallScaleSmitty
- 875 Views
Last post by markt311
