Vintage Optima Turbo Gears
Hi,
I'm new to the forum and hoping somebody might be able to steer me in the right direction!
I'm currently in the process of bringing back to life my old Beagle RC car from the late eighties, which is essentially a Maplins clone of a Optima Turbo. I believe its exactly the same.
One of the things I wanted to do on this project was to upgrade the old motor, speed conroller and battery to something more modern. I have done this by installing a 2S lithium power pack along with a Crazepony sensorless brushless motor (5200kv) and ESC. In hindsight I believe this is part of my problem, as the power from that motor has given me gearbox issues with chewed up gears. Going forward I think if I can't replace the gears for metal ones, I may need to replace the motor with something a bet less angry, or maybe program the ESC to output less power (if thats possible).
Anyway, onto my initial problem. I'm now at the point where the gear on the differential is chewed and needs replacing, and the external cluser gear is also not in a great state so probably needs replacing.
So.....these vintage parts appear to be like hens teeth but the "re-issue" version of the Optima Turbo appears to have parts (including that differential) readily available. Will they fit? Also, are metal gears available? I expect not.
Would I need to replace the gearbox housing with the re-release optima turbo version?
Any help much appreciated as I'm currently very stuck!
Images as follows (sorry I couldn't work out how to embed them in the post!)
https://ibb.co/LSBZXp6
https://ibb.co/KqDLLdp
Thanks
Thanks
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Re: Vintage Optima Turbo Gears
I think if u bought a rere gear case and all the rere gears/shafts/slipper etc it would probably fit.
Thanks coxbros1. Now to work out exactly what I need, and how much its going to cost.....maybe I could start by just purchasing the housing to see if it fits the chassis.
- coxbros1
good idea! U might want a little tamer "sensored" motor combo too! lol
Hi Derek,
Is there a controller/motor you would recommend for this that won't break the bank? I want it to be reasonably quick, but not stupidly so that it doesn't shred the gears!!
Thanks again
Thanks again
- TheDiamondOne
- Has thanked: 2077 times
- Been thanked: 588 times
Beagle, U can stay old school brushed and have good power.
Esc is : https://www.ebay.com/itm/124559527887
For the motor run: https://www.ebay.com/itm/Tamiya-Super-Stock-Motor-RZ-23T-TAM53697-/123932648639?_trksid=p2349624.m46890.l49292
Or for brushless run this combo: https://www.ebay.com/itm/Hobbywing-XR10-Justock-Sensored-Brushless-ESC-SD-G2-1-Motor-Combo-10-5T-/401594996342?_trksid=p2349624.m46890.l49292
- coxbros1
Sorry, next query.
Does anyone know where I can get (3d printed maybe?) the gear that is attached to the rear diff?
Basically this one (on the right):
https://www.ebay.com/itm/OT-27-Rear-Gear-Diff-Halves-Set-Kyosho-Optima-Javelin-Turbo-Optima-Salute/402672750312?hash=item5dc12a8ee8:g:jyoAAOSwnGJWTTVw
- Been thanked: 325 times
I personally wouldn't go as stout as a 10.5T motor for a vintage Optima, without a good bit of bulletproofing, and definitely not the chain drive. The chain stretches. I assume the Beagle uses a chain and not a belt? Also, the Beagle parts, though mostly interchangeable with the Optima as it was a clone, has inferior plastics. A better brushless combo I'd recommend that's a significant pile of bills cheaper, is one of the Leopard Toro 60A ESC combos. I would go with the 13T combo, or 12T but you'll want to dial down the punch on either setup. I have the 12T in my modded Optima Mid-converted-to-RWD-Mid, it's very smooth and plenty of power.
https://www.ebay.ca/itm/SkyRC-Leopard-1-10-Brushless-Motor-ESC-Combo-Program-Card-60A-V2-3000KV-13T-USA/181816072961
- 26 Replies
- 4897 Views
Last post by tamiyadan
- 994 Views
- 1879 Views
Last post by Mad Racer
- 68 Replies
- 23189 Views
Last post by Garage Hack
- 2847 Views
Last post by last5liter
- 3028 Views
- 20 Replies
- 3042 Views
- 3092 Views
Last post by Sparbolt
