Ballstud Rod End Foam Dust Covers
JackOTrades
Has thanked: 11 times
Been thanked: 40 times
Post by JackOTrades »
Hello All,
First, I have searched both the forum and google with little luck
1. Does everyone run/install the little foam washers/dust covers between the ball studs and the ball cups on their turnbuckles?
2. Can anyone recommend a good source for these little guys? I found a single NOS AE bag on ebay but have not been able to source a good supply for these.
TIA
Has thanked: 269 times
Been thanked: 2094 times
Re: Ballstud Rod End Foam Dust Covers
I generally only see them on restorations.
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
I live in a humid area and I noticed on the cars I had them on, the bottom of the ball studs were rusting. This only happened with the ones that had the foam dust donuts on them, and only where the donuts touched.
I've never used them and I don't really see the point in using them. I honestly think their imperviousness to dust is negligible as far as ball joint wear and tear goes. It probably makes a tidy profit for the companies manufacturing them out of tidbits of sponge foam.
TRX-1-3
Has thanked: 2066 times
Been thanked: 992 times
Post by TRX-1-3 »
Theoretically sound but effectiveness is questionable. They do something but will you notice a marked increase in ball / cup life?
For a 100% manual specs build for the shelf they would be a must I suppose.
What if you beveled some metal pipe/tubing and "die-cut" your own? The hole in the middle though....maybe some precison X-acto plunge cutting? Trying to think of a source for the thin foam.....
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
The old trick of the red o-rings popped up once or twice to seal them and remove play, dunno how much friction they added though as I never tried it.
JackOTrades
LowClassCC wrote: Fri Feb 12, 2021 8:13 pm I live in a humid area and I noticed on the cars I had them on, the bottom of the ball studs were rusting. This only happened with the ones that had the foam dust donuts on them, and only where the donuts touched.
This is good feedback. So the sponges were acting like sponges.
Thanks
Users browsing this forum: No User AvatarElkcycles, No User AvatarNickB, No User AvatarSemrush [Bot], User avatarXLR8 and 6 guests
