Hot Trick, What the... Rise of the Monster Beetle!
BattleTrak
Has thanked: 1153 times
Been thanked: 624 times
Post by BattleTrak »
Just received this Hot Trick Red Prince/Blackfoot chassis. I have another one that I am building up with Imex dual wheels and 8 tires.. but just couldn’t pass this one up. Wow..whatta mess! Front end isn’t bad, msc & rats nest wiring, Losi motor, hopefully Kyosho gold shocks..then the elephant in the room..what kind of gear box is that?!?
It doesn’t look handmade, no diff action, can’t turn rear axles by hand, appears to have two counter gears inside.. a tractor pulling gearbox??
Stay tuned for the teardown..
-Brad
BattleTrak
Re: Hot Trick Blackfoot. What the...
Electronics removed.. Airtronics 94631 servos, rx and a RC10 MSC?
-Brad
coxbros1
Has thanked: 2758 times
Been thanked: 2407 times
Post by coxbros1 »
Very cool! Gotta find out what Revolution it is....either a Killer, Brutus, or Insane
BattleTrak
coxbros1 wrote: Sat Feb 06, 2021 2:47 pm Very cool! Gotta find out what Revolution it is....either a Killer, Brutus, or Insane
How do I tell?
-Brad
BattleTrak
Front end removed..
Note the increased rear track width and spacers..
Rear end assembly removed..funny how this massive structure was only fastened down by (4) 4-40 screws!
-Brad
BattleTrak
Quick clean on the chassis and esc shelf. Has a lot of extra holes but minimal running wear..
Rear end breakdown..
-Brad
R Cane
Has thanked: 159 times
Been thanked: 64 times
Post by R Cane »
Waiting on the opening of the trans...
BattleTrak
-Brad
coxbros1
Post by coxbros1 »
"How do I tell?"
not real sure...hopin someone on here knows how.
Dadio
Has thanked: 2759 times
Been thanked: 2250 times
Post by Dadio »
That gearbox was made by the guys that made Stonehenge! Might last as long too!
BattleTrak
coxbros1 wrote: Sat Feb 06, 2021 4:36 pm "How do I tell?"
Armature has a “1” or “I” on it with a white paint mark.
-Brad
BattleTrak
Anyone seen a gear box like this? It has a massive gear reduction, machined housing, all gears ride on bearings, locked differential using Thorp parts.. I am pretty sure the dogbones and rear axles are Thorp too.
-Brad
threesheds
Has thanked: 59 times
Been thanked: 71 times
Post by threesheds »
Given me some ideas for a box of Meccano I've got....
coxbros1
Post by coxbros1 »
Its a double turn, so its an "Insane" (15x2) or a "Killer" (14x2)...the "Brutus" which is the holiest of holy grails is a triple (16x3)
BattleTrak
After going cross-eyed counting all the teeth on the gears... this gearbox has a final drive ratio of 114 to 1! Anyone want to play tug of war?
-Brad
Return to “Tamiya Forum”
