I need to replace the 32-21 Compound Gear in one of my Rocky's. This is the one the motor directly drives.
Found these two auctions by the same seller. One is listed as an "RD-11" and the other "RD-22". The latter is a couple of dollars more, but they both use the same images, and they appear the same as the Rocky part (don't know what the Rocky part number is)
RD-11 - https://www.ebay.com/itm/RD-11-Idler-Gear-32-21-Tooth-Kyosho-Raider-Outlaw-Raider-Series/254805145254?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Db349a016dc3141a08f5aba518587ffa3%26pid%3D100675%26rk%3D5%26rkt%3D15%26mehot%3Dnone%26sd%3D324427300113%26itm%3D254805145254%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DKyosho&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A836a99c4-4fd2-11eb-9113-32e843a4f227%7Cparentrq%3Ad5d288111760ad355125ca9fffe8a21f%7Ciid%3A1
RD-22 - https://www.ebay.com/itm/RD-22-Idler-Gear-32-21-Tooth-Kyosho-Raider-Outlaw-Raider-Series/402630337593?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Db349a016dc3141a08f5aba518587ffa3%26pid%3D100675%26rk%3D4%26rkt%3D15%26mehot%3Dnone%26sd%3D324427300113%26itm%3D402630337593%26pmt%3D0%26noa%3D1%26pg%3D2380057%26brand%3DKyosho&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3A836a99c4-4fd2-11eb-9113-32e843a4f227%7Cparentrq%3Ad5d288111760ad355125ca9fffe8a21f%7Ciid%3A1
Just curious if either or both of these will work in the Rocky
RD-11 vs RD-22
- Has thanked: 179 times
- Been thanked: 155 times
RD-11 vs RD-22
Losi LXT (JRX-T Conversion)
Losi JRX Pro SE
Kyosho Rocky
Parts-Car-to-Runner Kyosho Rocky
Yokomo YZ10 WCS '95 Pavidis
RJ Speed Spec10 "Chew Toy Mk1"
Redcat Lightning STK "Chew Toy Mk 2"
Kyosho Lazer ZX, ZX-R, ZX-RR
Losi JRX Pro SE
Kyosho Rocky
- Has thanked: 1130 times
- Been thanked: 3922 times
Re: RD-11 vs RD-22
RD-11 was the entire gear set, RD-22 was just a pair of idlers. Same idlers, just packaged differently. The seller has parted a set to sell them that way, and has thus just assigned his own part numbers. Neither are wrong, but RD-11 should be a whole set and RD-22 should be a pair of idlers.
Re: RD-11 vs RD-22
Awesome! Thanks for the info!
Losi JRX Pro SE
Kyosho Rocky
Losi JRX Pro SE
Kyosho Rocky
