Kyosho On-Road Gas?
- Has thanked: 3 times
Kyosho On-Road Gas?
After letting everything sit in plastic tubs for years, I am finally pulling out the last tub. This tub had the odds and ends including this car. My ex-girlfriends neighbor had this and no longer wanted it so it ended up with me. Not being into nitro, I put it on a shelf and ended up packing it away before college. I have no idea what it is other then obviously being Kyosho. The wheels are aluminum and the motor turns over. I don't know if the body is stock or aftermarket but that is what I got with it. I also got what appears the remains of an offload chassis for parts. Any one know what this is so I can try and find a manual and add it to my winter projects?
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Kyosho On-Road Gas?
The car with the wheels is a Kyosho Nitro ZR-1 vette. It was based on the rampage chassis. The cylinder head is a Duratrax or O’Donnel. The wheels are just plastic with a metal plating.
The other car started as one of the rampage series as well, but has had some cutting and some parts swapped around.
Thanks for the quick answer. Did a quick look around and there are some parts out there for it but prices are crazy. Finding an original head will be fun. I guess this will be a long term project. I don't see this being a re-release either.GoMachV wrote: ↑Tue Aug 25, 2020 12:19 am The car with the wheels is a Kyosho Nitro ZR-1 vette. It was based on the rampage chassis. The cylinder head is a Duratrax or O’Donnel. The wheels are just plastic with a metal plating.
- 616 Views
Last post by orangemazda
- 3804 Views
Last post by lifeIsAnalog
- 501 Views
Last post by Elkcycles
- 1170 Views
Last post by tim.sanderson
- 1276 Views
Last post by Hcp22
- 1608 Views
Last post by LTO_Dave
- 4828 Views
Last post by Antonov
- 19 Replies
- 2470 Views
Last post by Phin
