Narrowing rc10b3 frontend
- Regular Member
I am thinking of a project using a rc10b3 I picked up. I measured the rear width at ~225mm, from the outside edge of the wheels, and the front at ~245mm. Is there a way to narrow the front to match the rear width? Moreover, is there a way to do so while converting to 12mm hubs?
Re: Narrowing rc10b3 frontend
The 12mm hex conversions generally add some width. You can find a pair of b2 or I think b3 carpet arms are also shorter. The b2 arms would narrow it up like 6mm total. Not sure on the b3 carpet arms. Otherwise there are other buggy arms you can try. That would be the easiest.
- Has thanked: 35 times
- Been thanked: 10 times
b2 arms are hard to come by .... Did you check this post:
https://www.rc10talk.com/viewtopic.php?f=38&t=39211
- Has thanked: 59 times
- Been thanked: 71 times
I know nothing but are steering arms the same front and back, ie move backs to the front. Or is the difference due to any other part. Dogbones are theoretically the other part to move.
As I said , I know nothing
- Been thanked: 4 times
Have you tried B4 (bearing) front wheels?fasteddie911 wrote: ↑Sat Aug 22, 2020 11:58 am I am thinking of a project using a rc10b3 I picked up. I measured the rear width at ~225mm, from the outside edge of the wheels, and the front at ~245mm. Is there a way to narrow the front to match the rear width? Moreover, is there a way to do so while converting to 12mm hubs?
- 1366 Views
Last post by Jerzi
- 823 Views
Last post by MelvinsArmy
- 803 Views
Last post by gtv1
- 788 Views
Last post by HorseNZ
- 829 Views
Last post by broodenburg
- 2181 Views
Last post by SiRacer420
- 46 Replies
- 5614 Views
Last post by Jimbo302
- 839 Views
Users browsing this forum: DotNetDotCom.org [Bot] and 7 guests
