restoration of the magnesium motor mount, any tips?
hi all, im restoring a 94 yz10, and wanted to clean the magnesium motor mount up, i want it to look orginal, and dont want to polish it. any suggestions on what the best product or method to use would be?
- Has thanked: 659 times
- Been thanked: 878 times
Re: restoration of the magnesium motor mount, any tips?
Glass bead blasting works great then spray a couple light coats of clearcoat on it to keep it from oxidizing again.
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
I used mothers polish and just polished the tarnish away. I hoped the inbuilt wax would prevent it from tarnishing again but I haven't looked at it in about 2 years.
- Regular Member
I just cleaned my magnesium parts in an ultrasonic cleaner (Branson 200) with tap water and mild dish soap. the corrosion and dirt is gone and the surfaces are now smooth to the touch. They still have a tarnished look which I think of as patina and am happy with it. I assemble cars with a little carnauba wax on hand for hinge-pins, and self tapping screws into plastic so everything I touch gets a waxy finish (and smells lemony fresh). Oddly the front bulkhead has a different "look" of shiny silver instead of mid to dark gray.
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
I'll second Mike's suggestion as I have used it on all my Yok magnesium parts and finished with the light coating of clear, works really good and just to be clear it's "glass beading" not "sand blasting".
This is all very interesting!
- Has thanked: 80 times
- Been thanked: 21 times
I just got an ultrasonic a weekend ago, will definitely have to try this with my magnesium parts I have laying around!countrumford wrote: ↑Fri Aug 14, 2020 11:01 am I just cleaned my magnesium parts in an ultrasonic cleaner (Branson 200) with tap water and mild dish soap. the corrosion and dirt is gone and the surfaces are now smooth to the touch. They still have a tarnished look which I think of as patina and am happy with it. I assemble cars with a little carnauba wax on hand for hinge-pins, and self tapping screws into plastic so everything I touch gets a waxy finish (and smells lemony fresh). Oddly the front bulls head has a different "look" shiny silver instead of mid to dark gray.IMG_4776.jpeg
- RC10resto
- Has thanked: 1488 times
- Been thanked: 550 times
Your front Bulkhead may be Aluminum.countrumford wrote: ↑Fri Aug 14, 2020 11:01 am Oddly the front bulkhead has a different "look" of shiny silver instead of mid to dark gray.
I used a coffee machine descaler powder like (Puly Cleaner), you only need to dip the bulkheads for about 30 seconds, you get a bit of a volatile reaction, but straight out on to clean water. The parts go black, but that washes off with dishwasher powder, you won't believe how silver they come out... mine are better than new!
- 1794 Views
Last post by szac
- 19 Replies
- 3335 Views
Last post by obsidian
- 5065 Views
Last post by AscotConversion
- 1338 Views
Last post by Mad Racer
- 1217 Views
Last post by pottok
- 621 Views
Last post by GoldRush
- 678 Views
Last post by Mr. ED
- 1979 Views
Last post by klavy69
