Hi,
I want to add 10 degress of castor to my King Cab using the RC10 Block carriers.
My understanding is i would need to buy the 20 degree castor blocks as these would be -10 degrees as the stock kickup on the RC10 was 30 degrees? I would then flip them and run in revers on the king cab. Is this correct?
E.g So RC10 30 degrees block carriers are actually 0 degrees as they do not add or take away fromt he stock 30 degree kick up of the RC10?
30 = 0' on the carrier
20 = -10'
10 = -20'
5 = -25'
Adding castor using RC10 Block Carriers
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Adding castor using RC10 Block Carriers
The logic standssnowfox wrote: ↑Thu Apr 30, 2020 10:37 am Hi,
20 = -10'
10 = -20'
5 = -25'
yes that's correct how you are thinking. One note, you will have to grind out a section of the c-hub, there is a thicker part on the front side that will now be on the back side and interfere with the spindle travel. depending on how much throw you need, you can notch out the bare minimum to preserve strength.
- 1640 Views
Last post by Orange
- 2501 Views
Last post by ChisaiKuso
- 1098 Views
Last post by SteveK
- 879 Views
Last post by JosephS
- 1736 Views
Last post by shane
- 1667 Views
Last post by sandkil
- 681 Views
Last post by ca-rj
- 2196 Views
Last post by NeonNoodle
Users browsing this forum: Amazon [Bot] and 3 guests
