My RCovid10 Project
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
My RCovid10 Project
I’m sure many can relate to cabin fever due to the Covid19. I gathered a bunch of parts and built this RCovid10. Some of the parts include: Sassy chassis, Rogue wheels, Losi Bellcrank, RPM nose, RPM gear cover, alloy shock spring collars, and dhawk alloy parts.
- Limestang
- Limestang
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
- GeneralZod
- Has thanked: 150 times
- Been thanked: 162 times
- limestang
Re: My RCovid10 Project
I really like the rogue wheels and knock-offs. I had to convert the front axles to 4-40. I also did a few mods to the wing tubes (notch for dhawk setscrew, shortened length, machined a decorative band to match body mounts, and chamfered the wing wire holes for easier install). Also, found something to use the plastic knock-Offs for:)
- ChisaiKuso
- Has thanked: 5 times
- Been thanked: 27 times
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Very nice build
The rear stub axels have me stumped. I don't remember ever seeing those before.
Chuck
Chuck
- limestang
Thanks, glad you like it. I believe they are from an Rc10T2. For some reason Dhawk went with the newer style Axle.
-Limestang
-Limestang
- Jeep-Power
- Has thanked: 56 times
- Been thanked: 52 times
Great build.
So many questions-
How much does it weigh?
How do ypu like the fit & finish of the Dhawk parts?
What is the part # of that RPM gear cover?-- EDIT -- found it
So many questions-
- limestang
As shown with the addition of an unpainted body 1lb 13oz. Dhawk parts fit pretty well. I had some issues with the hinge pins being a tight fit. I put the he hinge pin on an electric drill and essentially reamed the hole.Jeep-Power wrote: ↑Tue May 05, 2020 10:07 pm Great build.
So many questions-
Hope this helps
- Limestang
- Jeep-Power
wow - 29oz- that is surprisingly light! - my all stock goldpan, without motor & body - with wheels, is 32oz - my sons '10, RTR, less battery, is 44oz
I thought, for sure, it was going to be heavy
- 2420 Views
Last post by TycoTamiya4eva
- 2321 Views
Last post by Truckguy
- 24 Replies
- 5483 Views
Last post by sbcnyc
- 152 Replies
- 18614 Views
Last post by DHC6
- 3386 Views
Last post by LosiXXkid
- 2241 Views
Last post by R Cane
- 26 Replies
- 3592 Views
Last post by Volumiza
- 974 Views
Last post by Hillbillyrcer
Users browsing this forum: Semrush [Bot] and 2 guests
