hottest motor for 6 gear trans????
guys, what the hottest wind motor you have ran in a 6 gear trans w/o killing it? I'm going to make a runner out of the 10 i won on ebay and would like to run a modified in it, but don't want to tear up the tranny......any suggestions?.............
- Been thanked: 12 times
Re: hottest motor for 6 gear trans????
I'm running a 17turn double speedgems sapphire in my 6-gear runner with no problems so far. The trans has full bearings and is holding up well after a few packs run through.
- Has thanked: 36 times
- Been thanked: 1318 times
you can put whatever motor in it that you want to. just stock up on idler gears.
Yea, scr8p is correct on that. A buddy that I used to race with was BAD about using really hot winds in his cars. But, he knew every trick to make a six gear last.
"Sometimes in life, you ain't gotta like it. You just gotta do it." Quote from my own SUPERDAD. RIP 5/10/14
- Erich Reichert
jeez we used to run 14 and 16 quads in those back in the 80's on our dirt oval. Yes you will wear out the idlers... probably a little faster on offroad then oval.
- 539 Views
Last post by bennettj325
- 1355 Views
Last post by jackflak
- 800 Views
Last post by shredderboy
- 1166 Views
Last post by Russ Winn
- 23 Replies
- 2571 Views
Last post by CamplinP
- 1074 Views
Last post by SUPERDAD
- 967 Views
Last post by littleVETTE
- 759 Views
Last post by Chris K
