Hi,
I'm refreshing my first RC car which happens to be a Gold pan A-stamp RC10 that I raced when I started out 30+ years ago. Prior to the re-build, the car was box stock. I have 2 questions:
1) Is there a simple upgrade to the dogbone's? Id like to replace with a CVD / Uni joint but keep the standard 6 gear outdrives which it currently has.. Is there an AE ebay option that would be a direct replacement that will work with the stock hubs & bearings? I cannot recall what the later Team Car or Worlds had or if they are available.
If anyone could provide a part number that would be great.
2) Is there a simple way to remove the gold shock snap rings from the bottom of the shock body? My nap ring tool is way too large and I can see that if I try to pry it out, it will become a projectile, never to be seen again!
Cheers
Brent
A stamp RC10 questions
- JTSpeedDemon
- Has thanked: 25 times
Re: A stamp RC10 questions
Sorry can't help you with either of those, but HEY! You got an A stamp too! Neat! Hope you can get it fixed up!
Original Cadillac A stamp AE RC10 with Hot Trick parts! That's how I roll!
- Has thanked: 660 times
- Been thanked: 878 times
That small snap ring if you pry it out with a small screwdriver just cover the end with a rag while you are removing it and you wont lose it.
- lexus-5
- Been thanked: 11 times
Hi, question 1 the Associated CV part number is ASC6371.
Regards
Regards
Remember it's either a runner or a shelfer. Everything else is just parts.
Check out my Gallery for more Collection Pictures http://www.rc10talk.com/viewtopic.php?f=77&t=20697
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Hi there!
I could be wrong but if your A-stamp has 1/4" axels the part could be 6369.
Lexus knows Rc10s better than I but I thought it might be at least another part number to search for.
Good luck, fairly rare.
Chuck
Chuck
- Attachments
- 6369.JPG (15.7 KiB) Viewed 798 times
- 3134 Views
Last post by SoCalSnakeEyes
- 346 Views
Last post by morrisey0
- 114 Replies
- 13982 Views
Last post by YakkityYak
- 1172 Views
Last post by Jeffrysource11
- 2708 Views
Last post by teman
- 2089 Views
Last post by klavy69
- 169 Replies
- 11017 Views
Last post by GreenBar0n
- 1026 Views
Last post by mikea96
Users browsing this forum: Bing [Bot] and 13 guests
