Length of ASC 9754 CVA Bone
I have a CVA but not sure which ASC number it is. I believe it might be a ASC 9754. Tried finding the length end to end online but no luck. Can anyone help with this?
Thx!
Thx!
Re: Length of ASC 9754 CVA Bone
that part number is listed as a b44 rear bone. As far as I recall, these are used typically with the WOIN builds and are slightly shorter than B4 bones, which I think are 67mm. So they are likely 65-66mm. the RC10 bone is about 60-61mm I believe.
now, the other issue is how that dimension is measured. I think everyone does it differently, where I think it should be center to center of the pin-pin or pin-cup/ball center. Some companies list the overall length, which isn't truly useful honestly.
at some point, I wanted to make a thread listing a bunch of bone lengths, but never got around to it.
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
The 9754 according to Associated should measure ... 9754 Rear CVA Bones B44 B44.3 RC10B44.1 62.7mm c/c, 68.7mm e/e
I pulled one side off a B4/B44 setup I have on a car and measured appx. 62.5mm center of pin to center of pin.
Pretty sure you add about 6mm to find overall length.
Chuck
Chuck
Yes the pic is great thank you. With my less sophisticated measurement device I’m about 63-64 mm. So it’s likely the 9754.
Thanks guys!
Thanks guys!
- 851 Views
Last post by BACK_AT_IT
- 991 Views
Last post by guggles
- 6118 Views
Last post by TRX-1-3
- 535 Views
Last post by mikea96
- 851 Views
- 609 Views
Last post by vintage AE
- 554 Views
Last post by juicedcoupe
- 1911 Views
Last post by cautiousone
