#4 RC10T build “Classic Carbon”
KidAgain
Business Member
Has thanked: 513 times
Been thanked: 431 times
Post by KidAgain »
New project in the works going carbon fiber chassis, towers and batt strap. Aluminum/titanium hardware will be used throughout, threaded FT shocks will be used also. Body has been chosen which I will unveil soon as the rolling chassis is complete same with wheels (vintage RPM’s). Lots of new and used parts will go into this build since I’m having a hard time finding arms and stuff.
One thing I need is some opinions on transmission choice.
1) Carbon fiber TrackMaster belt drive
2) Carbon fiber TrackMaster direct drive
3) Thorp 64 pitch Stealth trans
4) Stock Stealth trans
Here she is:
Lavigna
Has thanked: 1099 times
Been thanked: 1418 times
Re: #4 RC10T build “Classic Carbon”
Post by Lavigna »
Sounds like it's going to be a great project. I am not familiar with either Thorp or Trackaster, so I can't help you out. I do know that you can't go wrong with Factory Works, MIP, RPM, or Stealth transmissions.
KidAgain
Business Member
Post by KidAgain »
Started to put some stuff together:
clintf
Has thanked: 24 times
Post by clintf »
That is looking really sharp so far! The carbon fiber and blue aluminum looks classy and clean. Are those Blackfoot tires that were on it?
KidAgain
Business Member
Post by KidAgain »
clintf wrote: Mon Jul 01, 2019 6:15 pm That is looking really sharp so far! The carbon fiber and blue aluminum looks classy and clean. Are those Blackfoot tires that were on it?
Thanks bud, not sure on the tires all they say on the sidewall is ‘ALL TRACTION UTILITY’
KidAgain
Business Member
Post by KidAgain »
Decided to go with the TrackMaster Carbon belt drive and run a 13.5 brushless setup.
KidAgain
Business Member
Post by KidAgain »
Didn’t really feel like making a carbon rear trans brace so I made these turnbuckles connected to a bridge on the trans.
Also changed the steering to the AE bearing version mounted in the forward position.
KidAgain
Business Member
Post by KidAgain »
Some better pictures guys, installed modified nose tube braces took a little fiddling but I think they came out great.............
clintf
Post by clintf »
It looks like it's coming together nicely. With a 13.5 it should rip.
KidAgain
Business Member
Post by KidAgain »
Wheels/tires have been chosen, shocks ready to be built and THE BODY :shock: :mrgreen:
Image Image
Just a rear end shot :wink:
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Looking good :)
KidAgain
Business Member
Post by KidAgain »
Some sexy shots :P
KidAgain
Business Member
Post by KidAgain »
Body fitted rear will come down a bit more with all electronics... :mrgreen:
arndogg
Has thanked: 7 times
Post by arndogg »
looks good. gives me ideas on my build as well. Which body is this? I was wondering if there are other choices out there besides the JConcepts F150
KidAgain
Business Member
Post by KidAgain »
arndogg wrote: Sun Jul 14, 2019 1:23 pm looks good. gives me ideas on my build as well. Which body is this? I was wondering if there are other choices out there besides the JConcepts F150
The body is a TBG Nissan king cab I purchased from eBay seller ‘teambluegroove’ you just have to raise the front and rear body posts just a tad.
Return to “RC10 Truck Forum”
