My RC10t first post on here
first off i like seing all your guys builds on here. so here is a truck I built from some parts i have collected over the years. will post some more pics later i used sc10 cva and rear hubs. also used sc10 shocks. which i have upgraed to big bores since these pics.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: My RC10t first post on here
First of all welcome to the board.
Secondly, I can't see the pix. Keeps sending me to a sign in page for Google I think.
By chance can you just upload the pix to the forum here?
Thanx
Thanx
- klavy69
- Moderator
Yep, can see them now...kinda. Had a touch up on my left eye for lasik last monday so everything kinda blurry but seems to be on the right track since I'm seeing pix
- RABIDFOX50
- Has thanked: 10 times
- Been thanked: 5 times
I’m diggin the yellow. I also,like the new and old mix you got there. I’m toying with the idea of using SC10 CVDs on a T2 chassis I have in my collection in need of them. I want to keep the original rear hubs but use the hex mounts for modern wheels. What did you do up front? Modern spindles or just went with the originals?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
I can only see some of the pix, the others are blocked (at least on the first post) and I like what I'm seeing. The "all black" look is pretty cool. Those RPM arms will make the truck unbreakable but also a bit bouncy as they flex a lot, that's how they are so robust
Nice one... always happy to see a 10T coming back to life! I think this is the RC10-based design that has aged the best, performance-wise!
Any running video?
Paul
Any running video?
Paul
i used newer sc10/t4 spindles with hex adapters.RABIDFOX50 wrote: ↑Tue Mar 19, 2019 8:32 pm I’m diggin the yellow. I also,like the new and old mix you got there. I’m toying with the idea of using SC10 CVDs on a T2 chassis I have in my collection in need of them. I want to keep the original rear hubs but use the hex mounts for modern wheels. What did you do up front? Modern spindles or just went with the originals?
thank you. and i should get some picks of it at our local carpet track soon. needs some work on the handling side. i nee some more steering. it does not want to turn.Lonestar wrote: ↑Wed Mar 20, 2019 4:07 am I can only see some of the pix, the others are blocked (at least on the first post) and I like what I'm seeing. The "all black" look is pretty cool. Those RPM arms will make the truck unbreakable but also a bit bouncy as they flex a lot, that's how they are so robust![]()
Any running video?
Paul
Wow, I'm new. I didnt realize you could update so many parts, those shocks and axles, hexes, slipper. I got some reading to do.
- 6238 Views
- 2034 Views
Last post by THUNDERSTRIKE1
- 2044 Views
Last post by Mr. ED
- 1065 Views
Last post by Daddeo
- 19 Replies
- 2780 Views
Last post by CaptWill
- 871 Views
Last post by zhiland
- 328 Views
Last post by COZINATOR1960
- 1151 Views
