Cam pro motor setup
Rc king29
Cam pro motor setup
Post by Rc king29 »
Does anybody know if there are any resistors I must use on these motors if any?
Dadio
Has thanked: 2759 times
Been thanked: 2250 times
Re: Cam pro motor setup
Post by Dadio »
If you use vintage radio gear then it was often a good idea to use a capacitor to reduce RF interference from the motor but not so necessary with modern radios on 2.4gig radios .
Rc king29
Post by Rc king29 »
I am using vintage radio gear so if I put any old capacitor on there it will be fine? I have some but I just didn’t know if there was a certain one I needed to put on it. Thanks for the response. I e been trying to figure that out for a while now.
brushed motors should as a general rule, use three 0.1uF-0.47uf caps, one from each brush to the can (or screw tab) and then one across the brushes. the value isn't super critical, whatever you can find that falls in that range.
Some forward only ESC's recommend a schottky diode as well, it's up to your discretion. you have to be mindful of polarity.
Rc king29
Post by Rc king29 »
jwscab wrote: Wed Jun 06, 2018 8:38 am brushed motors should as a general rule, use three 0.1uF-0.47uf caps, one from each brush to the can (or screw tab) and then one across the brushes. the value isn't super critical, whatever you can find that falls in that range.
Will either of these work? The yellow say 508 act while the green say 1h102k
Yup either set of caps will be fine. The greens ones are a little light in value (102) is only 1000picofarads. Not sure about the others the values aren't present but judging by size they are within the right range.
Rc king29
Post by Rc king29 »
jwscab wrote: Fri Jun 08, 2018 9:29 pm Yup either set of caps will be fine. The greens ones are a little light in value (102) is only 1000picofarads. Not sure about the others the values aren't present but judging by size they are within the right range.
Thank you so much. I’ve been wanting to use that motor ever since I got it but I didn’t know about capacitors. Huge help.
