I was checking out the RPM website and I noticed that they had posted that the #70442 front arms do not fit the team car and yet I have several nip sets that has “team car addition “ printed on the header card. I have not opened the packages yet but they look to be same as the AE wide arms.
Can someone please set me straight on this??
RPM also states that the rear arms #70542 will not fit the team car.
Please help. I do not want to open these parts if they will not fit.
Thank you
RPM A-arms on a rc10 team car
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: RPM A-arms on a rc10 team car
They are incorrect on their team car statement- fronts and rears fit the original car, CE, Worlds, and Team car as well as both rere kits. The rears do require the early longer hinge pins however, so you will likely need them unless you have an earlier car. Rpm sells them as well. Part number is a 70590. You could size those up before you open the bag
- 1654 Views
Last post by Minicooper 35
- 2756 Views
Last post by sandkil
- 640 Views
Last post by Saito
- 1051 Views
- 29 Replies
- 8434 Views
Last post by juicedcoupe
- 2117 Views
Last post by joe sumasky
- 1102 Views
Last post by mikea96
- 1441 Views
Users browsing this forum: curl [Bot],
howsyouraspen and 2 guests
