Unique Suspension
Forum rules
- Has thanked: 1129 times
- Been thanked: 3919 times
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
Re: Unique Suspension
Are those rotary dampers? Like a Model A!
That's a sweet car, more pics? Anyone on here got one?
- mk-Zero
- Business Member
Interesting, yeah I guess they wouldn't need any air or bladders, should be much more consistent and have less stiction. Cool "out of the box" design for sure. Although rotary dampers are quite old.
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
That's an awesomatix - it's a russian DTM EP car that is having a bit of a cult following, because (1) it is disruptively innovative (2) it is beautifully executed, no cut corners (3) last but not least it performs (very) well on the track... if you can put in the time testing it, because setting it up, as you can guess, can be a bit of a challenge
The oil shock absorbers are helicoidal, think Hydradrive if you want. you cannot change the fluid but you can adjust them externally
There are two "core" versions: a shaft- and a belt-driven one... with some crazy features for the shaft one like a floating front bulkhead to prevent torque-twisting the chassis under ac-/dec-eleration, etc...
The car is expensive, there are constant (expensive) updates, but this is such a beautiful and crazy design... and it works. But boy is it demanding if you want to go fast with it.
you can see the first proto (from 2007...) here:
http://www.redrc.net/2007/04/prototype-russian-ep-touring-car/
For the record and to toot my own horn, I coined the nickname "Problematix" for it, and that name has got a bit of a following too: at least two (maybe three?!?) of my racing buddies use it
Awesome design, but I wouldn't run one for anything in the world
- Mr. ED
- XLR8
- Has thanked: 1684 times
- Been thanked: 1180 times
Agree, the tranny is a fascinating design. However, knowing that bevel gears are less efficient at transferring power than straight cut gears, why do you suppose they are utilizing three sets of bevel gears where only two sets are required (one at each end of the center drive shaft) if the motor was mounted longitudinally? Is it due to the torque reactive nature of the motor's armature and how it could affect handling?
Edit: Also, having the spur on a separate shaft will make it easier to replace. I have a ProSC 4x4 and its spur is fixed to the center drive-line and accessing it is a real pain; you must split the rear gear case to remove the spur.
- Attachments
- ProSC.jpg (55.61 KiB) Viewed 1492 times
- Has thanked: 9 times
- Been thanked: 9 times
They make some of the cooler cars I've seen, but I haven't heard many positive firsthand reviews of the performance. Maybe its a setup issue. Either way, the innovation is great to see, and might provide some ideas for other manufacturers... until traxxas patents it anyway.
- Lonestar
- Been thanked: 325 times
Nahh...Traxxas won't try to patent something truly unique...they might try to patent carbon fiber, or nuts & bolts, though. Or maybe they'll patent the gear.Timmahhh wrote: ↑Tue Dec 05, 2017 1:07 pm They make some of the cooler cars I've seen, but I haven't heard many positive firsthand reviews of the performance. Maybe its a setup issue. Either way, the innovation is great to see, and might provide some ideas for other manufacturers... until traxxas patents it anyway.
- 1104 Views
Last post by isobarik
- 1145 Views
Last post by LTO_Dave
- 24 Replies
- 2822 Views
Last post by MOmo
- 1812 Views
- 1301 Views
Last post by InetRC
- 1105 Views
Last post by b0x
- 28 Replies
- 3347 Views
Last post by MOmo
- 992 Views
Last post by DerbyDan
