Hi
I have 2 Acoms AM receivers (AR-227FE) that I got in a lot of parts. I think they are brand new but when I tried to test them I could not make them work. I only have futaba servos so I think it could be a problem with the wire position on the connector. I don't need those and I'd like to sell them. Do I have to switch the wires around for those receivers? If so what position should be the red, black and white wire then?
Thanks for the help...
Acoms receivers do I need to change wire position?
- Incredible_Serious
- Has thanked: 1737 times
- Been thanked: 1145 times
Re: Acoms receivers do I need to change wire position?
Acoms should be the same as Futaba, signal-positive-negative. Was usually only older Sanwa and KO stuff that had the negative in the middle.
- 881 Views
Last post by moj
- 1438 Views
Last post by TomEG
- 1284 Views
Last post by TomEG
- 1302 Views
Last post by vintage AE
- 1099 Views
Last post by LusBus
- 2265 Views
Last post by superfly
- 1012 Views
Last post by Danf1275
- 1199 Views
Last post by urban hype
