Steel gears
Vand_rc
Steel gears
Post by Vand_rc »
Is there someone who makes all 6 steel gears for the transmission or any way to swap a newer transmission with steel gears? I really need to get steel gears because I am running a brushless system. I'm not going to get rid of this one to get a newer one either.
Re: Steel gears
You can use the lower steel outdrives gears as idlers. Just cut the outdrive section off.
clm
Has thanked: 100 times
Been thanked: 205 times
Re: Steel gears
Post by clm »
you can take a spare set of lower gears and cut the outdrive off them to make idler gears. That gives you a full metal transmission on the cheap.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
Vand_rc
Re: Steel gears
Post by Vand_rc »
Thank you, I'll have to try that. That will help a lot.
