Any Good Radios Out There??
Looking to buy a nice (but price wise) Transmittter and reciever for my 2.5 T-maxx. Steering servo was bugging out. I switched the throttle and steering wires from the reciever and steering on the throttle channel worked great. Of corse the throttle bugged out. So I have diagnosed my problem to a radio malfunction. Soo I'm on a search for a good 3 channnel transmitter/reciever than wont break me. TY
- NomadRacer
- Has thanked: 81 times
- Been thanked: 79 times
Re: Any Good Radios Out There??
Futaba 3PV, goes for 110 - 120 bucks, depending on where you buy from.
Bum on Direct Deposit
- Basher67
- Has thanked: 44 times
- Been thanked: 160 times
I like the traxxas 2.4 link radios. Doesn't really have the easy access to fine tuning like you would want for a racing transmitter, but for bashing around a big nitro truck they git-er-done. I have one that came with my 4x4 vxl slash and I was happy with it enough that I just picked up a few more compatible receivers to put into my other basher trucks so I can just use 1 transmitter for all of them. You can pick up these radios pretty cheap on ebay.
- bully
- Been thanked: 6 times
+1 for the new budget futaba radios. Had a 2PL 2.4ghz for years an was very good,updated to the 4PLS and after some getting used to the way the menus an adjustments work I really like it.. The most recent budget type futabas look great...
- Has thanked: 100 times
- Been thanked: 205 times
Actually, once you add the bluetooth module to have access to tuning via your phone or other mobile device the tuning is supposed to be quite easy.
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- lmw94002
- Been thanked: 9 times
I bought a simple FlySky GT-3C radio for like $50. It was my first "modern" wireless radio and I didn't want to go too crazy. Coming from using my Airtronics 3PS and M8, the radio seemed to have a lot of configuration options. I use it with my RC10, B6D and SC10.2. Raced both the B6D and SC10.2 on a weekend with it. Seemed to work really well for me using Castle and Hobbywing ESCs with AE and Savox servos.
The only comment I would have... it doesn't feel super-sturdy compared to my older radios. I don't know if that's a new vs. old thing or a "cheap" vs. quality thing. Or even just do to the weight of the radio. It's not seen super heavy use, but I've been using it for ~6mo w/o any issues.
--Builds--
--Builds--
- abailey21
New radios mostly all feel very sturdy. Its the lower end ones like flysky that don'tlmw94002 wrote: ↑Fri Jun 16, 2017 3:05 pm I bought a simple FlySky GT-3C radio for like $50. It was my first "modern" wireless radio and I didn't want to go too crazy. Coming from using my Airtronics 3PS and M8, the radio seemed to have a lot of configuration options. I use it with my RC10, B6D and SC10.2. Raced both the B6D and SC10.2 on a weekend with it. Seemed to work really well for me using Castle and Hobbywing ESCs with AE and Savox servos.
- yellowdatsun
More than anything in RC, with radios you get what you pay for. Buy cheap, get cheap. Don't waste your money on anything under $100, unless it's a used radio. I have an Airtronics MT4 and a Futaba 3prka, and the MT4 is a way better radio. Both in feel and control. Yes, the nicer radios do control the car better.
- Has thanked: 9 times
I agree that more expensive radios generally have a more solid feel, but I think your description may overstate the differences. I've driven with $500 futaba radios, and $50 spektrum radios, and I wasnt any faster with a more expensive radio. When I got back into RC on a budget a few years back, I even used a radio with all analog adjustments and won my fair share of races. A fancy futaba or airtronics is more satisfying to hold, but I didn't notice any difference in how well it controlled the car. Even if there was a few millisecond difference in response rate, its nothing I could tell.yellowdatsun wrote: ↑Mon Jun 19, 2017 9:59 am More than anything in RC, with radios you get what you pay for. Buy cheap, get cheap. Don't waste your money on anything under $100, unless it's a used radio. I have an Airtronics MT4 and a Futaba 3prka, and the MT4 is a way better radio. Both in feel and control. Yes, the nicer radios do control the car better.
- Basher67
I find that the ease of range of adjustments on the higher end radios makes it worth the money at times. Yes, my traxxas link radio works just as well as my Spektrum DX3S, but the initial setup is kind of a PITA on the traxxas. I personally believe that the best radio depends on the user. Someone new to the hobby or just not a serious racer is going to be frustrated with all the adjustments and fine tuning that some of the higher end radios have. I agree that you get what you pay for, but there are plenty of good quality, base model radios, that work just as good as the expensive high optioned versions. Digital displays and telemetry feedback does not make the servos respond faster. A buddy of mine that is new to the hobby, bought a $60 radio at our lhs and loves it with his T3.
- Basher67
Part of that "lack of sturdiness" may be that the old radios took 8 AA batteries and most modern radios only use 4, Making them considerably lighter.
yep, i will second the fact that the radios are essentially half the weight or more, lending to a 'cheaper' feeling.
4 AA's, plus the electronics are just simple little boards, no long telescoping antenna. It would be cool to have a nice radio with aluminum or steel grip inserts to give it a more solid/heavier feel. Suppose it's a lot nicer to hold the lighter radio for longer periods of time though.
- lmw94002
I raced again this Sunday... Yeah, the GT3C worked well for me. Of course other than model memory w/ Trim and endpoint adjustments I haven't used all the other settings. Weight is definitely part of it for me anyways... no need for a next strap with the modern radios.
--Builds--
--Builds--
As was suggested here, I have been well pleased with the futaba 3PV. Seems to retain the traditional futaba durability in a lighter package. Good value.
- yellowdatsun
- 532 Views
Last post by y2kgtp
- 27 Replies
- 2559 Views
Last post by vintage racer
- 2263 Views
Last post by JK Racing
- 1154 Views
Last post by GJW
- 575 Views
Last post by Jay Dub
- 1301 Views
Last post by Wild27
- 49 Replies
- 5786 Views
Last post by juicedcoupe
- 2927 Views
Last post by Kyoshojoe
