kyosho raider
GAMMACRUSH
kyosho raider
Post by GAMMACRUSH »
hi guys i might be coming up on a kyosho raider but dont know much about it. i know its vintage. but is it cool? does it have a fan base any info at all would help i did a search but didnt find in depth info. thanks guys!
shodog
Been thanked: 91 times
Re: kyosho raider
Post by shodog »
Not really my cup of tea. It's a full on plastic buggy and more on the entry level side of things. you can search the Tamiya club site and see a few in peoples showrooms. If you wanted to go with a vintage Kyosho, you should look for a Scorpion or Ultima
Spiderman
Re: kyosho raider
Post by Spiderman »
Sold a crap load back in the day.
GAMMACRUSH
Re: kyosho raider
hmm not so special then... well.. it might be cool to have who knows maybe ill meet the right person and they want it. its all good.
Spiderman
Re: kyosho raider
Post by Spiderman »
They sold a crap load of RC10s back in the day too. 8)
GAMMACRUSH
Re: kyosho raider
hehe =] nice
Brandon G
Re: kyosho raider
Post by Brandon G »
Raider was the Kyosho step down from the Ultima.
Mostly plastic, but as far as collectability goes,,,,, ?
cowsrneat2002
Re: kyosho raider
Post by cowsrneat2002 »
I have 2 little boys, that are 5 and 6 years old. They are very curious of my cars. I have some incomplete Kyosho Raiders laying around that I have gotten with other ebay garage sale items. Was wondering if some people have the following items laying around. They do not have to be new. These will be backyard bashers. But anyhoo, the parts are as follows:
14 tooth, 32 pitch pinion
Counter gear from the (RD-11 Gear set)
RD-17 Swing shaft unless there is something else that is compatable
Rear chassis support from the (RD-01 Chassis set)
The antenna holder, switch cover from, and steering servo mounts (RD-04 Plastic parts )
Would it be better to get the original wheels, tires and radio gear for the Raider?? Maybe, I should get some newer applications intsead?? If I were to get newer tires and wheels, what would be some compatible options. Thanks any help would mean alot. :)
Brandon G
Re: kyosho raider
Post by Brandon G »
The newer Kyosho buggies have hex drive for the rear wheels. Probably fit, but offset might be a touch off. Fronts should work too, maybe need a different size bearing to make work. Avid has cheap ones if needed. These wheels for the newer Kyosho 2wd will of course allow use of newer 2.2" tires. The older 1.9" wheels/tires would be a bear to get a hold of.
If you need a set of orange rears, almost new condition, give me a pm. Got a set of NIB yellow fronts too.
GJW
Re: kyosho raider
Post by GJW »
turbo raider 8)
cowsrneat2002
Re: kyosho raider
I actually have some decals and bodies for the 2WD and Turbo Raider. Just need to get a couple of chassis from ebay for parts, get some up to date wheels to incorperate new tires. Throw on some duratrax speed controls and radios, so my little boys can have some bashers.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Re: kyosho raider
Post by Mr. ED »
bngiles wrote: Fronts should work too, maybe need a different size bearing to make work. Avid has cheap ones if needed. These wheels for the newer Kyosho 2wd will of course allow use of newer 2.2" tires. ...
The new 2wd rims will not work on a raider; that is if you are referring to ultima rb5 ones.
The rb5 does not have bearings in the wheel like the raider. The bearings are in the steering knuckle.
Jay Dub
Re: kyosho raider
Post by Jay Dub »
I have all of these NIP Raider parts. LMK if you would like them (any or all) and we can make a deal. (the x# is the # of sets of each that are available). -Jeff
RD-1 Chassis set-x5 (3 complete, 2 partials ) - Raider
RD-2 Front suspension mount - x5
RD-4 Raider 2wd -x5
RD-5 Upper arm/king pin -x6
RD-6 Shaft set - x6
RD-7 front wheel shaft - x3
RD-08 Metal set
RD-12 Gear box set - x3
RD-29 Raider pro wheel set
RD-36 Bumper/body mount set -x3
Brandon G
Re: kyosho raider
Post by Brandon G »
My bad. I didn't know they Losi'd up on this last buggy :oops:
Return to “Kyosho Forum”
