White dish modern wheels for LXT?
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Hi guys
gotta find white rear rims for my Slo-Hobby car ( ) , as time has come to ditch the old tires mounted on the old yellow ones... might as well buy something that looks about right ;)
What are modern, readily available, white dished rims that fit on the good ole LXT, please?
Thank you :)
Paul
Lonestar
Re: White dish modern wheels for LXT?
Post by Lonestar »
18 Viewers that don't have an answer :shock:
:lol:
matt1ptkn
Has thanked: 80 times
Been thanked: 133 times
Post by matt1ptkn »
I read your post yesterday, but I figured someone would have a better answer than I... :roll:
Probably not the answer you are looking for, but XXXT wheels should fit the rear, but not the front. HPI made (still makes?) a universal 5 spoke wheel that will fit all around, however, will make your width much wider. That's as modern as I go. :lol:
Matt
Lonestar
Post by Lonestar »
Cheers, thanks for trying ;)
would anyone know if AE T2 rears would fit?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2985&P=7
10T fronts work (or are close enough!)
Thanks guys :)
yes, I believe the T2 wheels will fit. certainly the right axle and pin size. And I think they all pretty much have the same offset.....
Lonestar
Post by Lonestar »
Cheers Joe - will order stuff tomorrow then and report about the fit when done :) Thank you!
badnat
Been thanked: 11 times
Post by badnat »
So what Paul!!! Does it fit finaly?
I have a LXT to restore since my son felt in love with the trucks looking at the sessions during the VORN2017 ...
Cheers
Nathaniel
Nat
(Top Force Evo++ - Lazer ZX++ - Triumph - TRX-1 - YZ-10 94' )
Lonestar
Post by Lonestar »
badnat wrote: Sun Jun 25, 2017 1:53 pm So what Paul!!! Does it fit finaly?
Cheers
Nathaniel
Your kid is smart :) Trucks are awesome to watch!
I wouldn't recommend a LXT though... bit too much work to keep running compared to a T4, for instance. I have a truckload of parts, which is good as there's a few things which are somwehate fragile in the end on the car and hard to source in 2017.
Rims: No idea... never came to order them.... will do sometime this summer I guess. My son decided he likes the 4wd SC better to do backyard bashing with Dad... and i like the challenge of bald-tires car, makes the driving more interesting ;)
badnat
Post by badnat »
So i made some experimentations with T4.1 rims.
In the Front, no problem it fits very well (exactly the same as the Losi rims) but most of you already know that :wink:
In the rear it fits well but there is an offset of -4.5 mm compared to the losi wheels. This makes the rear about 1cm wider than with the stock parts in the end!!
My two cents
Nat
Nat
RCveteran
Has thanked: 26 times
Been thanked: 200 times
Post by RCveteran »
1cm, no one will notice or care is my guess. Go with it.
Been thanked: 3919 times
I am pretty sure I have a box full of A&L direct fit LXT wheels floating around here somewhere. I'll put up some pics when I find them
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
Or just use the Team Losi A-1022 XXT/NXT axles up front and then use XXT / XXXT wheels. Pro-line xxt and xxxt wheels also work well after the axle swap.
RCveteran
Post by RCveteran »
GoMachV wrote: Sat Aug 19, 2017 10:04 am I am pretty sure I have a box full of A&L direct fit LXT wheels floating around here somewhere. I'll put up some pics when I find them
If you mean these, they are still cheap on Ebay. No connection to this guy but have bought these from him in past and as represented.
http://www.ebay.com/itm/Team-Losi-JRX2-JR2-NXT-GTX-More-2-2-Rear-Yellow-Vintage-Wheels-by-A-L-Mfg-/380636166868?hash=item589faefad4:g:PDEAAMXQCndRhXfg
Naw those are the buggy wheels to make it truck width with lots of offset. The ones I'm talking about are the LXT and 10T (3/16) offset. These also do not need a special nut. I found the box, there are about 20 pairs left. I have fronts also but having a hard time finding them to get a count.
Lonestar
Post by Lonestar »
Still have to try some modern ones... been a bit too busy with other non-RC stuff this year... :?
Return to “Losi Forum”
Users browsing this forum: No User AvatarMojeek [Bot], No User AvatarTbot [Bot] and 4 guests
