Gotta be starting something...... (JRX-2)
- LosiXXkid
So, to start with, we have one nearly new JRX-2 chassis......
- Lavigna
- Has thanked: 1099 times
- Been thanked: 1418 times
Re: Gotta be starting something......
Dooo eeeet.....
- LosiXXkid
That is the plan but nothing's happening until these arrive....
- matt1ptkn
- Has thanked: 80 times
- Been thanked: 133 times
Did you get the towers yet???
Matt
- LosiXXkid
No, not yet......still waiting.
- LosiXXkid
And just when I wasn't expecting them to arrive, they turned up! The quality is excellent, and in 3mm CF they are exceptionally stiff, so I'm Very happy indeed. Add to that, they look very nice too...
If Todd ends up doing the original JRX-2 chassis, it'll be worth every single dollar!
- LosiXXkid
Re: Gotta be starting something...... (JRX-2)
A little progress this evening....
- LosiXXkid
Made a little more progress this evening....
Check out the tyre clearance using the XXX BK offset axles and two shock spacers.
- LosiXXkid
Thanks!
IIRC they are some older Proline XX wheels that I dyed black.
- Business Member
- Been thanked: 12 times
Looks great!!! Well done!
Find me on Facebook! @vintagercparts @f14chassis
- Lavigna
Very nice and clean.
- LosiXXkid
Thank you for the positive feedback.
I've decided to make a few changes in that the wild red steering arms and the antenna mount will be replaced by black versions although the red springs might stay. I have the later style battery cup which needs fitting and then maybe some electrics but I'm really not sure which way to go. Novak maybe???
It's also getting close to that time where I'm going to need to get a repro body for it and paint it up.......my least favourite bit.......and always has been......
Since this isn't going to be runner, I might replace the Hydra-Drive unit that's currently fitted to it and replace the extended top shaft with the standard primary gear shaft so that I can use the non-Hydra RPM gear cover that I've got.
I also need to fit the front camber and steering links to stop the front wheels from being all floppy!
- RCveteran
- Has thanked: 26 times
- Been thanked: 200 times
Very sharp, I've built a lot of custom X2's. My favorite was the modern racer I built that ended up with someone else here eventually and he won't sell it back to me
. Early Losi is fun to swap together a lot of different configurations. Nice build you have going.
I dug up the old thread, may be something useful in it for you or not. I did get this car on track a couple times before I got rid of it just in some practice sessions. It was pretty solid and with a little more tuning it could have been World Champion.
http://www.rc10talk.com/viewtopic.php?f=27&t=19073&hilit=RCveteran
- matt1ptkn
X2. I'd love to find a source for rere vintage painted bodies at a reasonable cost. I'd probably end up spending an unreasonable amount of money with said source.
Matt
- 31 Replies
- 2841 Views
Last post by aconsola
- 596 Views
Last post by XLR8
- 863 Views
Last post by SmallScaleSmitty
- 1896 Views
Last post by klavy69
- 1211 Views
Last post by juicedcoupe
- 856 Views
Last post by GJW
- 2652 Views
- 2538 Views
Last post by gpster
Users browsing this forum: howsyouraspen and 3 guests
