Vintage Ultima speed control question
- limestang
- Has thanked: 100 times
- Been thanked: 249 times
I'm in the process of putting an old Ultima back together. I do not have much experience with this brand. I wanted to double check the battery connection. Both the resistor speed control and the battery have the same polarity Tamiya connector. I'm assuming the battery should be female. Can someone confirm?
Thanks Limestang
Thanks Limestang
- Attachments
- Kyosho 2.jpg (18.41 KiB) Viewed 2130 times
- Kyosho 1.jpg (4.51 KiB) Viewed 2130 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Vintage Ultima speed control question
Both are correct. Kyosho was opposite of the industry standard.
No problem. Personally I'd keep the Kyosho stock and change the battery
Finally a good use for all those Tamiya connectors I replace on ESCs.
- limestang
Looking for wiring diagram for the 3 resistor wires (Red, Orange,Yellow) that go to the mechanical speed control on an original Ultima. I'm not seeing where they get soldered, I'm assuming of the 5 solder points, you use the inner 3. Secondly I need to know which color goes to which point.
Thanks Limestang
Thanks Limestang
Here's a couple pics from the tomahawk manual. I think it will help clear it up a little, even tho the hole count is slightly different.
Actually if the outer wires were all that were flipped it wouldn't make a difference, as long as the center was correct. I found mine stashed away...here ya go
- 1452 Views
Last post by rctenracer
- 1422 Views
Last post by Der Kommissar
- 1085 Views
Last post by TRX-1-3
- 945 Views
Last post by littleVETTE
- 1226 Views
- 4417 Views
Last post by BillKrueger
- 1377 Views
Last post by Racer_X
- 3829 Views
