Big PET bottle to make RC bodies
Chewbacca
Has thanked: 51 times
Been thanked: 108 times
Post by Chewbacca »
I made a plaster mold from a RC10 body years ago but never got around to actually shrink a bottle around it. Do you know of any source in CA to get the 3 liter soda bottles or 1 Gallon water bottles that are not ribbed? The length of the body is the limiting factor right now.
After the first test I want to make an extended Rad2 body for a mid-motor setup.
Thanks all!!!
*** POWDER - KING ***
Halgar
Has thanked: 146 times
Been thanked: 197 times
Re: Big PET bottle to make RC bodies
Post by Halgar »
I'm willing to bet you can get large sheets of the material you need from an art supply. You could also try a place like Tap Plastic.
Chewbacca
Post by Chewbacca »
Thanks,
the ideas WAS, to shrink a bottle around a plaster mold, like shrink tube.
It is almost ashaming to admit I'm an engineer, but I did not think about the fact that the material will of course shrink to the shortest distance between 2 end points of an inner angle, like between side windows and side of the body. I had read the bottle method on some German site and though wow that is cool without thinking it through.
I just did a first off with a 1 gallon water bottle, and the results are not close to what I was hoping for.
Of course the bottle was ribbed, and all the other stuff I've read were using 3l straight cola bottles, so that might be a factor.
So, who here has build a vacum chamber to make bodies? If I send a mold of a body, could someone make me one?
My main goal was to make an extended body for my mid motor Traxxas Rad2 / Graupner Radicator Expert. Since that body ends at the shock tower in the rear. Now in the mid motor setuo the shock tower is about 2 inches further back.
I like the thin style of that body, I am open for other suggestions.
Thanks, Tony
