** Build of the Month Contest - August 2016 ** - Winner - Headling
Moderator: scr8p
- Has thanked: 36 times
- Been thanked: 1318 times
Open Contest This Month! Any Manufacturer!
OK, this will be the thread for the August 2016 Build of the Month Contest.
GOOD LUCK!!!
** Place Holders **
GOOD LUCK!!!
** Place Holders **
Re: ** Build of the Month Contest - August 2016 ** - Winner - Headling
This is my 'first' rc10, that went through a ton of evolutionary changes. It was likely a mid production Caddy car that I got as a pile of used parts and no manual. practically nothing left original now.
as it currently sits freshly restored, it has a Houge chassis and arms, losi shocks with MIP seals, RRP 18 degree kinpins, Andys front arms. The 6 gear trans has thorp 48 pitch gears, bearing mods, and jammin' upgrades. Trinity universals and wheels. Jammin' Jumper body, and litespeed heatsink with parma gear cover. Techna turnbuckles and probably parma heavy duty rod ends. Custom front tower to fit the taller losi shocks.
Here's my build, had a lot of fun with this one. Used a RE-RE Worlds chassis, China made blue 10T nose plate, A&L steering, front and rear towers, & battery hold down, LRP speed control and motor, Niki's quadrasymetric suspension, Hot Laps tires front and rear, B4 wheels, and finished it off with a Proline Mirage SS body with a spin on the Worlds paint. Hope you like.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
This is an Academy GV2. You don't see very many of these around.
- Diamond Dave
- Has thanked: 699 times
- Been thanked: 130 times
A work in progress. I need some more detailing in the paint and body. Many different parts used to build it.
- Has thanked: 25 times
- Been thanked: 29 times
My RC10-LCG Astro racer:
RC10 meets Yokomo, a classic with a modern twist, it certainly surprises the modern cars on track!!
Full build thread and running videos here:
http://www.rc10talk.com/viewtopic.php?f=35&t=38681
The rules state to only put two pictures up
Thanks
Shodog
Thanks
Shodog
If in doubt go flat out!
- skunk.werkz
Tamiya Racing Masters MK.7 Porsche 956 chassis restored with original body
One of my XX-4 buggies. This the XX-4 WE. It is pretty much what i ran in the late 90's but i re-built it and gave a birthday. Its more or less stock with the exception of the Trinity shock collars, Motor clamp and motor plate / cam. I have it setup to the box setup and also have a Kinwald rear sway bar (not seen in the pics).
The motor is a Fantom 10x2 controlled by a Tekin TSC 410k that i stripped and re-wired. The servo is a Futaba FET servo (will check the model - forgotten!). The radio is a Futaba FP T3 with a Noval XXL receiver. All still works well, but the radio NiCds last for about 30 seconds then dump! I also have a nice set of SCRC 1700's that still hold a bit of charge to round out the buggy.
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
Here is my TRX-3.
And the garbage build thread (mine always start already built with random choices that change with no explanation
http://www.rc10talk.com/viewtopic.php?f=31&t=36001&start=0
The Cliff's Notes version:
A&L LW trans w/Stealth diff and PowerClutch slipper
A&L bones
Lunsford buckles
BB steering
TiN coated shafts
Spectrum 2.4 GHz
LRP IPC v3.1
Trinity 17x2 (speed gems re-re)
JR Z250 servo
RPM rear arms
RPM front Bumper
Fibrelyte towers and top deck
Thanks for looking.
Mark
A&L bones
Lunsford buckles
BB steering
TiN coated shafts
Spectrum 2.4 GHz
LRP IPC v3.1
JR Z250 servo
RPM rear arms
RPM front Bumper
Thanks for looking.
Mark
Got our 10. Get your pics up by the 7th.
Make sure you get your pics up by tonight.
- THEYTOOKMYTHUMB
- Has thanked: 3699 times
- Been thanked: 1980 times
skunk.werkz I'm unable to see your pics. Not sure if everyone else is having the same issue.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
x2THEYTOOKMYTHUMB wrote:skunk.werkz I'm unable to see your pics. Not sure if everyone else is having the same issue.
