Receiver wiring help
- HairTrigger
- Regular Member
Newbie question: what are these two black and red wires supposed to be connected to?
They come out of the receiver with the slot marked "batt."
I presume that is short for battery so do I need to run another small battery
just to these two wires? Or do they somehow connect to the main battery?
I've tried looking at pictures but can't find another setup that looks the same.
(Pics to follow)
(Pics to follow)
Ongoing Project: Ultima Pro
- Has thanked: 100 times
- Been thanked: 205 times
Re: Receiver wiring help
That looks to be a simple 2 pin plug that goes to a receiver pack. I would assume someone plugged it in then cut off the wires, you should be able to unplug the lighter colored connector?
As that is a BEC receiver you should not need it if your esc provides adequate power
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
- HairTrigger
- Regular Member
Right! Thanks for clearing that up. Trying to trouble shoot why the
car wasn't running, but ended up being mismatched crystals running
on different bands!
on different bands!
- 1768 Views
Last post by Libra
- 1161 Views
- 1105 Views
Last post by nvxwax
- 1049 Views
- 28 Replies
- 4072 Views
- 1943 Views
Last post by Dr. Robotnik
- 649 Views
Last post by FasterLouder
- 401 Views
Last post by Frankentruck
