DS resto.....
DS resto.....
So in beginning my plan I am realizing that there are no tires.....lol should have read more threads. So as I understand... The sc10 front turnbuckles fit and just get a hex clamp for rear axles and then I cause modern wheel/tire combo?
- romulus22
- Has thanked: 900 times
- Been thanked: 789 times
Re: DS resto.....
You should be able to find all your answers in here
http://www.rc10talk.com/viewtopic.php?f=37&t=31213
Re: DS resto....
Great post but mine is not a nitro and the sc10 hub has been discontinued. Wondering about other solutions?
- LoboNYC
- Has thanked: 870 times
- Been thanked: 356 times
Re: DS resto.....
HAHA Thanks Todd....Hope all is Well!!!romulus22 wrote:You should be able to find all your answers in here
thodgez28, It doesnt matter whether the DS is nitro or electric, we are talking about the front end, which is the same for both electric and nitro.thodgez28 wrote:Great post but mine is not a nitro and the sc10 hub has been discontinued. Wondering about other solutions?
As for the proline conversion hub, yes thats been discontinued....but you can use the hub from the associated sc10 2wd truck.
You need to enlarge the hinge-pin hole to accommodate the larger DS pin. i used a drill bit and spun it slowly. I used various sizes till i got the hole large enough for the pin to fit good.
now if you search this on ebay "Associated SC10 RS 2wd Front Axle Caster Block 12mm Hexes Rear Carrier Bearings", you can find a set; I just finished purchasing two sets for a couple of projects i got going.
This is a set on my electric DS Lambo
On Nitro
Good Luck with your project!
- 804 Views
Last post by noony
- 966 Views
Last post by Doc J33P
- 2485 Views
Last post by Volumiza
- 1567 Views
- 1453 Views
- 1720 Views
Last post by rc-stu
- 2677 Views
Last post by Jeep-Power
- 2101 Views
Last post by MelvinsArmy
