Mugen Manx
- hibernaculum
- Has thanked: 5 times
- Been thanked: 4 times
Re: Mugen Manx
Very interesting Dan. But are you absolutely certain the Panda Cyclone and Mugen Manx are independently manufactured cars?
Or was the Panda Cyclone actually a rebranding/repackaging of the same kit, with some bits different (like decals)?
i.e. Panda Cyclone
If significant molded parts, like gearbox, chassis etc are different, then I'm with you - they are different (one being an approximation, or clone, of the other) and it was not a rebranding exercise.
But a similar problem exists with the Mugen Mercury Xi-4 vs Academy Mercury Xi-4.
Is the Academy a clone of the Mugen, or a rebranding? If it's a clone, it's a little strange they even used the same name.
Mugen
Academy
I always had the feeling that the Academy and Panda releases were about another brand taking over the production or the design rights to the car, given that Mugen quit electric R/C in about 1990, and change their name from Mugen Engineering Co to Mugen Seiki.
Panda (aka Thunder Tiger) were Taiwanese. They now own Team Associated as everyone knows.
Academy were Korean, and better known for plastic model kits. Both were not above copying other brands, but cloning... I am less certain of this, since both had lines of their own legit products dating back to 1979 and 1969 respectively.
Happy to be proven wrong of course, it would simply be nice to get to the bottom of it
i.e. Panda Cyclone
Mugen
Academy
- TomEG
Re: Mugen Manx
Sorry for commenting on such an old post, but I find it interesting that both Panda and Mugen cloned the Air Supply "Ran.co One" body for the Cyclone and Manx.
- TomEG
Re: Mugen Manx
Great info Dan, I love this stuff!
Here is the original "Ran.co-One" body, designed by Tadashi Kurihara of Proto Design Co. for Air Supply. Tadashi Kurihara also designed most (maybe all?) of the Marui cars, as well as the Kyosho Sand Skipper series, Mr. & Miss Wheelie and the body for Kogawas Beetle.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Re: Mugen Manx
It's likely they exploited loopholes in their respective countries' copyright laws to produce cheaper copies of Japanese products. I once built a Academy model kit that clearly was a bootleg of a Gunze Sangyo model kit, including all the telltale marks that showed it had been reverse-engineered from an existing kit (tolerance issues with part fit, softened detail, copied decal sheet and instructions with the original copyright removed). In other cases, Korean companies produced products that looked like copies, but were actually licensed, despite the use of inferior materials.hibernaculum wrote: ↑Tue Apr 19, 2016 12:00 am
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
Re: Mugen Manx
Let's name a couple more buggies with designs that lean heavily toward the hornet/grasshopper design. I'll start with the Academy Roadrunner, Roadrunner2 and Lazer. They also had a military vehicle, I think a hummer, with the same base but monsterbeetle tires. And then there's Nikko with the 1/10 Bison (if I recall correctly).
I'm not sure, but the Ishipla Monster might be another one in the list. Graupner Pinto for sure.
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
Re: Mugen Manx
All this to clone a bloody hornet
some great connoisseur's info in this thread - thanks Dan and folks
- Mr. ED
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Mugen Manx
The Beagle was a pretty decent looking copy. The only other one I know is the Bluebird Baja/growler which had more of a Tamiya style suspension.
- Lonestar
Re: Mugen Manx
Well at least by copying the Optima they got their inspiration from something that actually worked on the track
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Re: Mugen Manx
Nah, I wouldn't classify the Ishipla Monster as a clone. Ishipla borrowed elements from other cars but put them together to make their own unique design. Front arms from a Grasshopper mated to an Ayk Buffalo rear end with Scorpion shock towers. Also had some class threaded shocks and other aluminum bits instead of just the fantastic plastic.
Also the Pinto was Graupner doing European sales for Panda's other Grasshopper clone: "The Panda"...which got "improved" with a ball joint rear suspension. You could also get The Panda with a Monte Carlo body as the Stocker or a truck body as the Danny Thompson Stadium Racer.
- Lonestar
Re: Mugen Manx
From my recollection, the Panda danny stocker/stadium had proper 4-wheel independend suspension... and were IC with a pull-start.Phin wrote: ↑Wed May 31, 2017 9:28 amNah, I wouldn't classify the Ishipla Monster as a clone. Ishipla borrowed elements from other cars but put them together to make their own unique design. Front arms from a Grasshopper mated to an Ayk Buffalo rear end with Scorpion shock towers. Also had some class threaded shocks and other aluminum bits instead of just the fantastic plastic.![]()
Was it really related to the graupner pinto/stadium? (which does look like a GH clone indeed)
- Mr. ED
Re: Mugen Manx
I see your point regarding the monster. I was just going by memory and it was vague
The optima on the other hand, I don't feel like it was cloned so often.
Edit: I somehow missed the above post before posting my reply. Do you have some pictures or names?
Mrc (the french company) used very optima like suspemsion, but was no optima clone since the drivetrain seemed more shumacher cat inspired in construction.
Any other clones of the hornet grasshopper that come to mind? Maybe the traxxas cat or marui coors? ( I left those out originally as I'm even hazier on them)
- Mr. ED
Re: Mugen Manx
In more recent times it was tamiya again which inspired lots of clones: I forgot the original name but now it's called the plasma edge.
And the baja king was a popular role model too.
- 2748 Views
Last post by silvertriple
- 3145 Views
Last post by urban hype
- 2449 Views
Last post by saga101
- 793 Views
Last post by Ambrose44
- 741 Views
Last post by Retro rc
- 4280 Views
Last post by BattleTrak
- 52 Replies
- 13010 Views
Last post by Mr. ED
- 2505 Views
Last post by Bormac
