RC10DS - White Parts Special
LoboNYC
Has thanked: 870 times
Been thanked: 356 times
Post by LoboNYC »
Story: A while back i got two DS cars in trade for a new in boxed tamiya f201 ferrari. One was restored into a Lamborghini DS http://www.rc10talk.com/viewtopic.php?f=37&t=36795.
The "RC10DS White Parts Special" was born from the second DS. First off, the chassis was scratched and then painted over with a black sharpe so a new one was needed. i acquired a full set of Dyno-Tech racing white nylon arms and thought of mating them to an anodized emerald green DS chassis i have been saving.
Then i thought i could use the carbon DS chassis i have...
Sandkil suggested a black and white themed DS carbon chassis build so it was begun.
The Dyno-Tech racing arms
i decided to take remove the black powder coating off the nose plate and engine mount with some EasyOff oven cleaner and sandpaper.
I swapped out the original stock DS black parts for white parts.
I replaced all brass bushings with bearings
Replaced the stock black ball ends with RPM white ones
The hubs and suspension arm mounts were placed on a carbon DS chassis by Xtreme Racing
The Dyno-Tech Racing arms are installed along with a set of GPM blue anodized front suspension arm mounts
Problem enountered with the white arms...they are missing the hole for the shock mount
Problem solved by removing the anti roll bar and reassigning the hole to fulfill shock mount tab duties. RPM long shank ball cup ends were needed to compensate for the reduced ride height caused by the repositioning of the shock.
White parts battery tray, antenna mount and a fiberglass battery brace
White part rear bulkhead and stainless steel hardware
Axle cups polished,blue anodized GPM dogbone used, White parts Axle hub and white a rpm ball end cups
White parts used on the team shocks as well
Angle Photos
The DS is equipped with a castle creations sidewinder 3 brushless/esc combo
RPM Radio Receiver box
Fully loaded
Body choice has not been made yet but more updates to come.
romulus22
Has thanked: 900 times
Been thanked: 789 times
Re: RC10DS White Parts Special
Post by romulus22 »
I've been waiting for this to pop up. The car looks awesome Alex. Black and white combo has been my all time favorite in the Associated cars progression.
hugger19
Has thanked: 25 times
Been thanked: 143 times
Post by hugger19 »
check out shapeways if u wanna make it more white they have a bunch of parts :)
very very nice and definitely unique on this board.
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
Looking nice. If you wanted white front arm mounts too you could mod a set of buggy front mounts and use a set of tapping inserts to reduce the 8-32 holes to use 4-40 screws.
http://www.mcmaster.com/#standard-threaded-inserts/=10wwf79
Not sure if the front shock tower would mount right up to them though.
durb69
Post by durb69 »
Nice looking build for sure! Looks killer!
you could always remove the anodizing from the arm mounts and give them some elbow grease to polish them up a bit.
if you are running it, you might want to work in the nose tubes somehow.
you could also look into making fiberglass towers to match the battery strap too.
1968
Post by 1968 »
I have a set of the front blue arms mounts that some idiot used a longer bolt and put a nut on top and scratched it. I was thinking about stripping mine but I really want to keep them blue.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
I really like how the wheels turned out. I have some scratched up chromies that might just get this treatment 8)
Looks great overall :wink:
LoboNYC
Post by LoboNYC »
romulus22 wrote:I've been waiting for this to pop up. The car looks awesome Alex. Black and white combo has been my all time favorite in the Associated cars progression.
Thanks Todd, Ive been wanting to post this for a little while now but i needed to make more progress. I have a set of long black RPM ball cup ends to replace the blue ones currently on the front shocks. The body choice is still up in the air...im waiting for an original DS BMW body to arrive. I may go original or just opt for an HPI body...im still thinking about it.
hugger19 wrote:check out shapeways if u wanna make it more white they have a bunch of parts :)
Thanks for the suggestion but i want to stick with original AE parts. At this point in time im not crazy about using 3D printed parts.
jwscab wrote:very very nice and definitely unique on this board.
Thanks, Maybe i will try mounting a unique body on it :D
Phin wrote:Looking nice. If you wanted white front arm mounts too you could mod a set of buggy front mounts and use a set of tapping inserts to reduce the 8-32 holes to use 4-40 screws.
Thanks Phin, cool idea but im sticking with the blue anodized mounts. I may just remove the blue and polish them to look like the nose and motor plate.
durb69 wrote:Nice looking build for sure! Looks killer!
Thanks man. I hope she runs as good as she is looking. I have a castle brushless setup waiting to get installed on her :mrgreen:
jwscab wrote:you could always remove the anodizing from the arm mounts and give them some elbow grease to polish them up a bit.
HAHAHA jwscab....i've had the removal of the anodized blue layer already on the brain...i almost started that, when working on the nose and motor plate...but had no elbow grease left, lol. Im definitely running this so incorporating the nose tubes has been on my mind since i started. i was trying the GT nose tubes along with the tube braces but its a tricky situation. i'll figure something out.
1968 wrote:I have a set of the front blue arms mounts that some idiot used a longer bolt and put a nut on top and scratched it. I was thinking about stripping mine but I really want to keep them blue.
I was going to say remove the blue anodize off them and polish the scratches off....but i just read you like the blue :mrgreen:
klavy69 wrote:I really like how the wheels turned out. I have some scratched up chromies that might just get this treatment 8)
Thanks Todd, Ive had those wheels for a while but never used them because it was just too odd......till this build. Now they feel right at home on this car :mrgreen:
sandkil
Has thanked: 795 times
Been thanked: 623 times
Post by sandkil »
Damn Alex!
That car would go nicely with my team car, nix91 and 10lss :wink:
Love your builds.
SFC K
Has thanked: 47 times
Been thanked: 9 times
Post by SFC K »
8) Nice looking DS! Those wheels turned out great too! Are you using the clear tubes on the front body posts for the body to rest on?
Jeff
LoboNYC
Post by LoboNYC »
sandkil wrote:Damn Alex!
Love your builds.
Thanks a bunch Erik....I take that as a compliment since your builds are outstanding and detailed. :mrgreen:
SFC K wrote: Nice looking DS! Those wheels turned out great too! Are you using the clear tubes on the front body posts for the body to rest on?
Thanks, I may end up de-chroming a few more wheels myself. The clear tubes were on the DS before i started the restoration...I left them on till I decide on the body. I usually use body clips with the plastic discs to support the body.
LoboNYC
Post by LoboNYC »
Heres an update to the RC10DS White Parts Special...
The rear of the car lacked a motor guard...i couldnt find one so i cut up an old chassis. I trimmed and attached it to the carbon chassis
I polished the outside of the guard....
.... and left the inside powder coated black
I had to trim the center so it would clear the tranny...hey what do you know? a "C" chassis :D
Fits perfect
Now for the front nose support. Someone chopped up the front nose area of a chassis and attched it to the carbon fiber chassis in order to support the nose tubes. That was really cool idea but i went a different route. I used a set of trinity nose tube braces for the RC10GT...something i got in the mail from Romulus22 one day a while back. THANKS ROMULUS22 THEY FINALLY WENT TO GOOD USE! I used the long GT nose tubes in order to get the braces farther back onto the wider part of the chassis. Each brace is secured to the chassis via two screws.
Im still contemplating on a body....
ra272
Been thanked: 7 times
Post by ra272 »
Really nice!! 8)
