Hi guys,
I'm wanting to install a full bearing set on my Optima 1st gen. There are a number of companies that make sets for the optima such as Avid and Fast Eddy. Is there any brand in particular that's better than the other? I also noticed that Team Losi made a set called Gold Seal bearings. Any thoughts on those?
Thanks
Optima bearings
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Optima bearings
The Trinity sets were NMB bearings which were and still are the finest you can buy. That said, you would never be able to tell the difference between those and a cheap set. The longevity maybe a little. Just get a set of either you mentioned and they will be more than fine
Re: Optima bearings
Good info! Thank you. I don't think I've seen the Trinity set for sale. From what I've read, people recommend cleaning out brand new bearings and then lubing them yourself. Is this really necessary? If so, what do recommend for lube?
- 19 Replies
- 1543 Views
Last post by RichieRich
- 543 Views
Last post by FordPSD
- 1239 Views
Last post by tbfoto
- 726 Views
Last post by sneako43
- 637 Views
Last post by cherokee
- 311 Views
Last post by tjf
- 1707 Views
Last post by RC10th
- 648 Views
