Rc10t switch to wheel bearings instead of bushings
Sorry for the noob questions,but I want to switch my rc10t over to wheel bearings instead of those gold bushings.
The truck has the 3 piece wheels which I plan on keeping. I figured out the bearings from my losi xxxt fit the front of the rc10t,but I can't find a bearing for the rear. Is there a bearing i can buy to just swap out with the gold rear bushing?
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Rc10t switch to wheel bearings instead of bushings
the bushings/bearings are 1/4" x 3/8" unflanged and are readily available in most good hobby shops.
http://www.avidrc.com/product/1/bearings/6/14-x-38-x-18-Metal-R168ZZ-bearings.html
yes, assuming you have stock bushings and an original truck carriers. If you are using a buggy rear carrier they will be flanged or if your using t2 3/16 axles they will be the same as front wheel bushings. assuming you have a truck that is unaltered, those are the ones
- 1060 Views
Last post by LoboNYC
- 840 Views
Last post by MONSTER
- 1331 Views
Last post by Phin
- 745 Views
Last post by rc10uk
- 985 Views
Last post by Brandon G
- 2176 Views
- 813 Views
Last post by unclemikey1978
- 4915 Views
Last post by jaro
