B3 full hex conversion
General info, Q&A.
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
For anyone whom wants to attempt it:
B4.2 carriers & knuckles (with hex, axles, bearings, etc)
Losi XXXT (confirming model) rear hubs, using the 'inner' hinge pin hole
B4.2 CVAs & hexes (or just B4 CVDs like I have here)
Drill the front carriers for 1/8" hinge pin
Shim rear carriers for near zero side to side play
Releive the brace on the rear arm (for CVD/CVA clearance as needed for droop)
Width to a standard B3
Width to a B5 rear motor
JK Racing
Re: B3 full hex conversion
Post by JK Racing »
Rear width shots dont show it, but it matches both the stock B3 and B5.
Rear carriers:
broodenburg
Has thanked: 35 times
Been thanked: 10 times
Post by broodenburg »
Why did you use the Losi XXXT rear hubs?
I've used RPM rear hubs (the ones with large bearings) and that seems to work fine. No droop issues either.
JK Racing
Post by JK Racing »
The car came to me with these hubs. Which RPM hubs did you use? Keep in mind, these hubs move the axle out to use B4 CVDs, which are longer than B3 units.
broodenburg
I used the replacement RPM b4 hubs (RPM70172). They are the same as b4.2 hubs and use lager bearings. Your correct: it pushes the wheel out so you have to use b4 CVD's.
JK Racing
Post by JK Racing »
Bringing this back up top, as I was asked about it :)
Should work on the B2 as well.
Timmahhh
Has thanked: 9 times
Been thanked: 9 times
Post by Timmahhh »
JK Racing wrote: Tue Jul 24, 2018 11:47 pm Bringing this back up top, as I was asked about it :)
That would require b3 rear arms though, right? Otherwise it seems that the CVA/CVD might be too long
JK Racing
Post by JK Racing »
Good point, had not thought about the B2 arms being shorter, probably front & rear honestly. This may not work on a B2
yeah, b3 rear arms at a minimum, depending on the bone engagement. B2 front arms just makes it slightly narrow, b3 ones are obviously wider.
BTW the difference is about 1/8" per side.
JK Racing
Post by JK Racing »
Can make up the front width difference with a wider hex (SC10.2). Rear, not so much...
