Ten4 parts list
Moderator: mk-Zero
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 21 times
Ten4 parts list
Here are the parts and options needed to build a Ten4 4WD RC10. Obviously a donor car is needed beyond what is listed here. For the Long wheelbase version, an un-cut noseplate is needed. Also note, you must use a 6565 rear transmission case (with the idler bearings mounted in the case), the World's re-release case will not work!
Associated Parts
Front Wheels:
9767 Front wheels (or compatible)
Front Drivetrain:
3438 Low Profile 8-32 nuts
7369 Axle Pin
9647 Steering Spacers
9749 Front CVA Kit
9750 Wheel Adapter
9751 Bearing Spacers
3977 3/16x3/8 bearings or equivalent (4 required)
Front Transmission:
3926 Diff Rebuild kit
6577 RH Outdrive
6578 LH Outdrive
6580 Diff Gear
6581 3/32 Balls
6906 3/16 x 3/8 bearings or equivalent, 2x
6903 3/8 x 5/8 bearings or equivalent, 2x
6589 5/32 x 5/16 Bearings or equivalent, 2x
CPD Parts from Shapeways
Please see this thread --> http://www.rc10talk.com/viewtopic.php?f=103&t=38929
NOTE: You need all the parts listed plus ONE of the three steering options, depending on your preference
The total cost for the CPD parts from Shapeways is about $110 plus shipping
Robinson Racing Parts
You will need the front and rear belt pulleys and the input/output shafts from Robinson Racing, which are made specially for the Ten4
Please see thread here for details and pricing --> http://www.rc10talk.com/viewtopic.php?f=103&t=39141&p=440038#p440038
GoSpeed
Front and rear shock towers come from GoSpeed, please see thread here for options and pricing
http://www.rc10talk.com/viewtopic.php?f=101&t=38683
Other Parts Needed
The rear tensioner uses 2x of 1/8 x5/16 x 9/64 bearings
1/8" X .60" shaft for rear tensioner
The front tensioner uses 2x of 1/4 x 3/8 x 1/8 flanged bearings
Miscellaneous hardware (screws, nuts, etc)
I offer a complete hardware kit that has the above items for $10, see thread here http://www.rc10talk.com/viewtopic.php?f=103&t=38726
For the long wheelbase version, you will need longer nosetubes. I offer them for $15 a set here http://www.rc10talk.com/viewtopic.php?f=103&t=38726
The belt you need for the long wheelbase version is 5973M6 Ametric® HTD Rubber Timing Belt, 3 mm Pitch, 597 mm Long, 6 mm Wide, 199 Teeth, 2.4 mm Over All Height, 1.17 mm Tooth Height. It can be purchased from Amazon here http://www.amazon.com/5973M6-Ametric%C2%AE-Rubber-Timing-Height/dp/B00HBWFOBK/ref=redir_mobile_desktop?ie=UTF8&keywords=5973M6%20Ametric%C3%82%C2%AE%20HTD%20Rubber%20Timing%20Belt%2C%203%20mm%20Pitch%2C%20597%20mm%20Long%2C%206%20mm%20Wide%2C%20199%20Teeth%2C&pi=AC_SX110_SY165_QL70&qid=1444573361&ref_=mp_s_a_1_1&sr=8-1
For the short wheelbase version you need the following belt: 5733M6 Ametric® HTD Rubber Timing Belt, 3 mm Pitch, 573 mm Long, 6 mm Wide, 191 Teeth, 2.4 mm Over All Height, 1.17 mm Tooth Height,(Mfg Code 1-093). It can be purchased through Amazon here http://www.amazon.com/5733M6-Ametric%C2%AE-Rubber-Timing-Height/dp/B00HBWEZRE?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Associated Parts
Front Wheels:
Front Drivetrain:
7369 Axle Pin
9749 Front CVA Kit
9750 Wheel Adapter
Front Transmission:
6577 RH Outdrive
6578 LH Outdrive
6580 Diff Gear
6581 3/32 Balls
GoSpeed
Other Parts Needed
Re: Ten4 parts list
Hey @mk-Zero
is this still a thing? Are the parts still available?
I'm looking at converting a 6 gear, but using an MIP box at the rear, Short classic front arms, and maybe a chain instead of a belt.
I don't quite understand about the re:re. gearbox not being suitable (idler bearings?) and wonder if I will have the same issue with the MIP box?
Thanks
Mark.
Thanks
Mark.
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Ten4 parts list
The parts Brian sells are still listed on shape ways for purchase. For the short arm, I have a version of the front carriers on shape ways since officially we didn't support them. They are documented here....
https://www.rc10talk.com/viewtopic.php?t=40561
The only parts that are not available from us are the idler and pulley set which you would need to create or make on your own. The rest of the AE parts are discontinued but you can source them used or on eBay etc.
As far as the rere stealth not working, it's because they moved the bearing from the case to the idler which won't work for getting power to the front wheels. Since the mip trans was used for the mip 4wd conversion it would have the bearing in the case so that isn't an issue but finding the proper 4wd idler might be. Using a different trans than the ten4 was developed for will be a struggle any way you look at it.
- breizhator2
Re: Ten4 parts list
Hi i'm trying to build a Ten4 but part isn't available.
9749 Front CVA
What can we replace it with ?
Regards
9749 Front CVA
Regards
Re: Ten4 parts list
A good portion of the parts have been discontinued. You would need to search ebay or alternative sites for some pieces.
It's a long shot but I have been working on a ten4.1. I DO NOT KNOW 100% THAT IT WILL HAPPEN AND WILL NOT COMMIT TO IT, but it is a current project I'm trying to get sorted with modern pieces. Please take note of the bold words above and I will NOT answer questions about it until it is further down the road.
- RC10superfan
- Has thanked: 109 times
- Been thanked: 13 times
Re: Ten4 parts list
Sounds great! Thank you for your efforts!GoMachV wrote: ↑Sun May 12, 2024 2:28 pm A good portion of the parts have been discontinued. You would need to search ebay or alternative sites for some pieces.
- 5733 Views
Last post by SFC K
- 1625 Views
- 1430 Views
Last post by a01butal
- 1183 Views
Last post by metallicats33
- 4832 Views
Last post by mamadoesntletme
- 1230 Views
Last post by LouCicconi
- 1315 Views
Last post by joel45acp
- 1309 Views
Last post by Kobur
