Project: LS1 Chevette
- romulus22
- Has thanked: 640 times
- Been thanked: 649 times
Re: Project: LS1 Chevette
The guy tuning the car has HP tuners. The computer was throwing an operating systems code or something along those lines. After he did some researching he found out someone had done some tuning with EFI live and it has put a lock on the settings or something. Basically it's trying to run with no MAF sensor or 02 sensors right now.
I think that's what I've gathered what's going on. It's all mumbo jumbo to me. He has a truck ECU he is going to set up for my car. Then he's going to do something to mine so I can sell it and recoup my money.
It has a stock cam, and I've deleted the EGR. All the evap stuff is deleted too just hasn't been pulled from the intake yet. But you are correct. I did have some open vacuum lines at the moment. Plugged them with my fingers and the car still only idles for a short bit. Once the ECU thing is fixed I'll go through and cap all the vaccum ports up. Thanks for reminding me
- Has thanked: 750 times
- Been thanked: 26 times
Hi,
I have seen these scanners before, that display engine parameters on your smartphone,
This one does Apple, Android and Windows phones.
http://www.ebay.com.au/itm/Mini-Wifi-ELM327-OBD-II-Car-OBD2-Scanner-Diagnostic-Support-Android-IOS-/282247215503?hash=item41b73eb98f:g:uBIAAOSwKOJYIAly
This one for Android.
http://www.ebay.com.au/itm/ELM327-OBDII-OBD2-WiFi-V2-1-Car-Diagnostic-Wireless-Scanner-Tool-For-Android-New-/152257666475?hash=item2373439dab:g:iOQAAOSwXSJXOYkn
This one is more expensive, and is Bluetooth, it powers down to stop battery drain.
https://www.amazon.com/gp/product/B00H9S71LW/ref=as_li_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=B00H9S71LW&linkCode=as2&tag=thegeaobscha-20&linkId=T7TYWQTJ2KXSB4KQ
Here is a 7 inch tablet with WiFi and Bluetooth to use as a dash,
http://www.ebay.com.au/itm/172352245935?_trksid=p2055119.m1438.l2649&var=471174697613&ssPageName=STRK%3AMEBIDX%3AIT
Wow, check this out!
https://www.youtube.com/watch?v=LLbEzEHscOI
[youtube]LLbEzEHscOI[/youtube]
I see he has gauges for Coolant Temp and Revs, I wonder if you can do Speed as well?
This one has Speed.
https://www.youtube.com/watch?v=GMYZNal9Wpk&spfreload=5
[youtube]GMYZNal9Wpk&spfreload=5[/youtube]
https://www.youtube.com/watch?v=NRl3m2UmkM4
[youtube]NRl3m2UmkM4[/youtube]
Does anyone have any experience with them?
This one has Speed.
Hi,
I tried this app on my Android Phone.
https://play.google.com/store/apps/details?id=org.mrchops.android.digihud&hl=en
While I couldn't get it to do a Heads Up Display, my phone is not bright enough,
I was able to use the phone just like a dash board for Speed.
- romulus22
Hey Dave thanks for those links, I had never seen such a product before. Only thing I don't like is it isn't a live connection. I still don't know what route I'm going with yet. Starting to lean back towards traditional gauges since my cluster is already shaped to hold round gauges. I'll just deal with no speedo.
Back to some progress. I've finished putting in the last two relays and fixed my steering. Having never modified a cars steering before I had no clue how much lowering the steering rack would affect the bump steering. I didn't try measuring it but I would have called it undrivable..... The bump steer is pretty un noticeable now while bouncing the nose. Just need to give it a final alignment and call it done.
Hi Todd/Romulus22,
Neither had I until I started researching it,
if your car needs to be inspected, I would say you need a speedo.
It is best to ask questions first and get it right the first time.
Saves having to take it back for a second inspection.
What is the law like where you are?
In Adelaide they are tough!
- R Cane
- Has thanked: 155 times
- Been thanked: 63 times
I run a bluetooth OBD2 adapter similar to the ELM327 you pictured. I just leave it plugged in all the time, and it's got a list of stats as long as my arm that I can choose from, that update constantly while I drive. It's pretty neat. Plus, of course, it will list any engine codes your car throws at you, and you can turn off the check engine light from the app also.
Good stuff.
I can post some screen shots of different things on there if you'd like.
Good stuff.
- Been thanked: 280 times
I use one of those too, for my Pontiac Torrent. With Torque Lite, it can view and clear codes and shows a pretty good variety of data info from the car. I bought the Pro version because it lets you log data, and monitors even more readings. I also use it to read trouble codes for my parents' vehicles, when needed. But I read that it might not be a good idea to leave it plugged in all the time, as it consumes a bit of electricity and could potentially drain your battery if the car is parked long enough, and because it's always broadcasting via Bluetooth, it's a potential security hole. Bluetooth can and has been hacked into.R Cane wrote:I run a bluetooth OBD2 adapter similar to the ELM327 you pictured. I just leave it plugged in all the time, and it's got a list of stats as long as my arm that I can choose from, that update constantly while I drive. It's pretty neat. Plus, of course, it will list any engine codes your car throws at you, and you can turn off the check engine light from the app also.
Hi Guys,
RCane, I am interested in seeing some screen shots.
Are you using the app on your smart phone?
The first 2 are WiFi, so you would set a Local Area Network with a
user name and password, and that would be more secure?
- romulus22
Thanks for the offer R Cane, I'm pretty confident I'll be going traditional gauges. But feel free to post pictures for others who may be interested. Heck it still peaks my interest even though I probably won't go that route. I hate technology as much as wiring. I haven't owned a computer in probably 7-8 years. I just use my phone for the Internet, call, and occasional text.
And here's another video. Bought some vacuum plugs, wired in the MAF sensor, still needs some computer tuning work but at least it runs now.
Time to fry the tires
[youtube]BQXrNh8aW7k[/youtube]
- romulus22
I stuck a stock wheel on and will need a 1" spacer minimum to clear the wheel tubs. Going to mount those so I can do a nice smokey burnout without destroying my expensive brand new tires.RC10th wrote:I was hoping for a bit of this......
Car is running and driving great now. Just cleaning things up at the moment like wiring and small details. Hopefully last piece I need to make is some adjustable heim joint end rear control arms. Parts are on order. Sitting stationary the car spins the tires smooth. If I'm rolling and I get into it and it starts spinning I get some wheel hop. Thinking that eliminating the soft rubber bushings and some stiffer shocks should eliminate all wheel hop.
Another side note is the car is super smooth even with the solid engine and trans mounts. If I had a big lumpy cam it may be a different story but stock engine it feels like any normal car.
- RC10th
- Has thanked: 39 times
- Been thanked: 997 times
Good to hear it runs and drives good, looking forward to some videos. Are you going to work the LS1 a bit or just leave it stock?
Hows the acceleration feel?
- romulus22
I think E ventually it will get an overhaul. Good heads, cam, intake, throttle body. I'm going to make some passes at the track next season to get a good starting point and evaluate how far I want to take it versus how much I want to spend.
Right now if I roll into it, it pulls very hard. It's shocked a couple friends so far. I'm still hopeful I'll get an 11.5 or better out of it. I think after I get my wheel hop taken care of and mount the slicks on a prepped track it's a pretty reasonable goal. If you do the HP/LB on a quarter mile calculator an 11.5 is playing it very safe. So we'll see in time.
- romulus22
Remember that wheel hop I was talking about. This time is did it bad. Nearly ripped the suspension out from under the car.
Here's the passenger control arm mount.
And what the rear control arm is supposed to look like.
It's not supposed to look like this
Went ahead and cut out some of the passenger side floor of the affected area. The drivers floor stayed intact due to all the metal work I did for my seat and new floor. I'm still going to redesign the control arm mounts on both sides. Just going to copy the passenger side over. Just need to wait on my heim joints to see if this 2"x3" tubing I have will work or not.
- 777 Views
Last post by 62 bugzilla
- 188 Views
Last post by TycoTamiya4eva
- 1531 Views
Last post by Truckguy
- 24 Replies
- 4552 Views
Last post by sbcnyc
- 2099 Views
Last post by R Cane
- 940 Views
Last post by tulsa
- 1132 Views
Last post by soniccj5
- 384 Views
Last post by Halgar
