my blue chassis rc10gt
hugger19
Has thanked: 25 times
Been thanked: 143 times
Post by hugger19 »
just won this rc10gt http://www.ebay.com/itm/321778764258?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
i know tbg sells rc10gt bodies, but which one is correct for this chassis/rc10gt. please post up ebay tbg body link on post. thanks mike
ALSO i was looking into swapping out the frt arms to rpm to match the rears. which ones do i buy rc10gt or rc10gt2 rpm frt arms?
DaveM
Has thanked: 727 times
Been thanked: 26 times
Re: need some info/help
Post by DaveM »
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
hugger19
Post by hugger19 »
RC10th
Post by RC10th »
That body would work, it came with the RTR blue chassis GT's while the other one came with the FT versions
hugger19
Post by hugger19 »
RC10th wrote:That body would work, it came with the RTR blue chassis GT's while the other one came with the FT versions
so this body would fit? http://www.ebay.com/itm/ASSOCIATED-6134-RC10GT-RC10-GT-TRUCK-BODY-VINTAGE-GAS-NITRO-/111591434767
RC10th
Post by RC10th »
It will work, just beware that the blue chassis trucks are longer then tub trucks.
hugger19
Post by hugger19 »
than ill go with this body looks to be a little longer plus its a little cheaper :D http://www.ebay.com/itm/151567770978?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
justinspeed79
Post by justinspeed79 »
hugger19 wrote:than ill go with this body looks to be a little longer plus its a little cheaper :D http://www.ebay.com/itm/151567770978?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
That body is a early tub chassis body and will not fit unless you do the early rear shock tower swap. The 6134 and the f150 bodies will both fit with no modification. Your truck appears to be either the "rtr plus" or "team built" version, which both originally came with the proline Chevy Silverado body.
hugger19
Post by hugger19 »
so is this the body u r talking about??? http://www.ebay.com/itm/Associated-Interceptor-Body-Clear-RC10GT2-ASC7992-/400927310954?pt=LH_DefaultDomain_0&hash=item5d5921446a
justinspeed79
No, that's the gt2 interceptor body. That body can work with some minor mods. This is the original. Was also available from associated in blue, and from proline unpainted. Unfortunately none of the original gt bodies are being made anymore (unless you count the tower hobbies ST15), and are not easy to find.
http://www.stormerhobbies.com/cgi-bin/seekpart.pl?pn=ASC7184R
hugger19
Post by hugger19 »
justinspeed79
Yes, that's the original gt body being resold by tower. That's also for the early narrow shock tower setup. Also, after looking at the gt2 body again, it looks like you would need to do the shock tower swap to run that one too.
hugger19
Post by hugger19 »
lol i thought finding a body was going to be easy. i think iam going with this one. http://www.ebay.com/itm/9516-RC10GT-RC10-GT-TRUCK-BODY-VINTAGE-GAS-NITRO-/151567770978 looks close to that rc10gt chevy truck body u sent me by stormer hobbies. thanks.
justinspeed79
There is also a guy on eBay selling painted crowd pleazer bodies that fit your truck. Look up the seller dsloomer and or search RC10GT body, It should be one of the top results. Don't search crowd pleazer, he doesn't list the name, I think because they are repops, but that's what they are.
Return to “RC10 Truck Forum”
