how hot of a motor can the rc10 classic take?
ea77
Post by ea77 »
Trying to determine for the electronics of the car.
matteo
Re: how hot of a motor can the rc10 classic take?
Post by matteo »
The manual states that is can take up to 8.5 turn brushless. They do not recommend anything lower for the 6 gear tranny.
ca-rj
Post by ca-rj »
The problem with the 6 gear is that you have to crank the diff nut down pretty tight so that it won't slip. I can't imagine the diff living long with a 8.5T. If I remember right, the mod motors of the day were 18-20 turn brushed.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
DaveM
Has thanked: 727 times
Been thanked: 26 times
Post by DaveM »
Hi,
I wish someone had told me, about the 8.5 turn brushless limit. :roll:
I have been running my 6 gear with black idlers and RCCA bearing mod using a 6.5 turn brushless
setup on GT spec foam tires on the indoor track at the local hobby shop, no traction compound
though.
Cheers, Dave. :)
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
I ran 10-13 turn motors all the time in a 6 gear...with 6 cell NiMh batteries. Dirt oval
I have ran a traxxas VXL motor in a 6 gear recently...thing was ballistic. Had the diff locked though like Ryan said.
ea77
Post by ea77 »
Doink
:lol:
Saw the reference to 8.5t as the fastest recommended motor in the manual. Thanks guys
The car is a rocket with 8.5t using the recommended pinion of 18t
Been thanked: 3919 times
DaveM wrote:Hi,
well, if you had read the manual, it is there in print. This was just a recommendation, if you choose to exceed it then fine! Its not a rule. The gears are not meant to explode at a certain rpm. Im really sorry you feel let down, perhaps a message to Team Associated would be more appropriate though, since they are the ones issuing the recommendation
:roll:
