Schumacher Cougar2 Works manual request
The place to request any scanned items you may need.
Lennard
Post by Lennard »
Do any of you guys know, where to find a Cougar2 Works manual?
Thanks Lennard
phoenix
Has thanked: 5 times
Been thanked: 19 times
Re: Schumacher Cougar2 Works manual request
Post by phoenix »
I have a cougar 2 standard manual if that helps to get you started.
Lennard
Post by Lennard »
Thanks, how big is the difference between the Cougar2 and the Works?
phoenix
Post by phoenix »
Here we go: http://www.retromodelisme.com/manuel_page/143/cougar-2-schumacher.html
The difference is not big (build wise), only in option parts.
Lennard
Post by Lennard »
thank you guys:-)
Has thanked: 1668 times
Been thanked: 1114 times
phoenix wrote:Here we go: http://www.retromodelisme.com/manuel_page/143/cougar-2-schumacher.html
The difference is not big, only in option parts.
Um......
There is a bit of difference.... the Works has it's own chassis (in purple), as it has a different gearbox (different mounting screw positions, different side plates in purple, different gear cover), and also utilises Bosscat rear hubs. Everything else that can be upgraded on the Cougar2 should be on the C2 Works as well (carbon fibre shock towers, ballbearing steering, roller driveshafts, slipper, Pro diff, pro shocks).
You could upgrade a Cougar 2 to works, there was a kit pretty much like the Stealth upgrade for the RC10 6-gear.... even included a drilling template for drilling the new gearbox mounting holes.
Lennard
Post by Lennard »
Ok, but is it not possible find a manual or a scan?
Return to “Scan Requests”
