Ordering brushless system
RC10 Graphite with stealth trans 2.25 , 81/21. Car used on street and off road messing around, no track. This is the combo im looking at. Not looking for max speed.
Hobbywing 60A ESC
Turnigy 2S 5,000 mAh Lipo
Reedy 3,300 KV
Question- what is boost? Does this esc have that?
Hobbywing 60A ESC
Reedy 3,300 KV
RC10 GRAPHITE
Stealth 2.25
81 spur/21 pinion
Reedy 3300kv
XP SP SC700-BL Brushless ESC
Stealth 2.25
81 spur/21 pinion
Reedy 3300kv
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
Re: Ordering brushless system
Only sensored ESC's coupled with sensored motors have boost and turbo. It is what's known as dynamic timing.
"Boost" is basically esc timing advance up to full throttle. Boost gives a feeling of added punch or an increase in power ie making a higher turn motor perform like a lower turn motor. This is fantastic for drivability.
"Turbo" is timing advance from full throttle till you back off. When you hit full throttle the timing still advances making the car continue to accelerate beyond.
Might want to replace the stock slipper as that will be the first one to give in with the power of the modern BL system.
HW has two flavour,either the xerun(sensored) ,or ezrun(sensoreless) are value for your money,have own the ezrun ans xerun(120 V2 &V2.1) so far no problems encountered.
Just dont forget to properly set the slipper or else it will fry your internals.
Heres mine with a 120A Xerun V2.1 tekin 8.5T motor.mod the slipper to use Avid triad slipper for max tuneability.
― Confucius
― Confucius
Wow thats a sweet graphite car!
Set slipper to the specs in manual or loosen it up?
RC10 GRAPHITE
Stealth 2.25
81 spur/21 pinion
Reedy 3300kv
Stealth 2.25
81 spur/21 pinion
Reedy 3300kv
I set mine similar to these steps.
http://www.rctech.net/forum/electric-off-road/512013-how-properly-build-break-ball-differential-slipper-clutch.html
You dhoild be ok.
You dhoild be ok.
― Confucius
― Confucius
- 1835 Views
Last post by askbob
- 3362 Views
Last post by natob2
- 20 Replies
- 1595 Views
Last post by slow_jun
- 2044 Views
- 1112 Views
Last post by Halgar
- 794 Views
Last post by lpddpd
- 1948 Views
Last post by Marshky
- 819 Views
Last post by TitleSeventeen
