Making a chassis mold width and length advise
Minisforever
Post by Minisforever »
Looking to get a little advise on width and length for my molds. Making a 30,25 and 20 degree angles. Any help would be appreciated
Been thanked: 3919 times
Re: Making a chassis mold width and length advise
If your making panels, 18x24 or 25 seems to be the norm
I want some 7-10 degree laid up for old school 4wd and fwd chassis 8)
sschering
Post by sschering »
Are you making flat plate with a kick up or a full molded pan on a plug?
gomachv.. how big of a piece are you looking for?
I don't have big enough pieces to make a 18x24 plate but a chassis size plate would be easy to do in the food saver bag.
The composite craft 30 degree chassis blank I have is 6x15.5" which should suit most projects
Minisforever
The reason I'm asking I have to make myself a chassis for a 1/10 buggy but didn't want to limit myself for future projects. Or help friends with their builds. :wink: Would a 8" wide by 16" length cover most builds? Buggy, truck and 1/8 scale.
Just planning on flat panel right now. Baby steps, I have a few different epoxys and would like to see how they respond to flat panels.
I think 8x16 is fine for most, but if this works out you might wish you went bigger so you can get more material made from one layup
Minisforever
That's the advise I like Jeff. I'm fronting quite a bit of money for metal plates and would prefer to do it once. What's your thoughts if I went 10x18? I worry about distortion if I go to big. This is a pressed mold which needs a different mold than a vacuum mold.
I made a vacuum mold to make carbon sides to my losi scte. 2 layers of carbon sandwiching a layer of Kevlar. Holding up very well.
The widest pan car I could find in my stash is 7" wide, an inch wider than any off-road I have seen. So at 7", how much area would you need around that for a buffer? I know my DA material has about 1/2" of unusable material on the outside. The carbon is wavy and sometimes it's just epoxy. Maybe that's not normal tho? Anyway, I think at 10" wide you would be wasting material. I would go 6" usable like composite craft or 12" so you can get two or a pan car. For length, I think 16 would cover most any 1/10 pan or off road
Users browsing this forum: No User AvatarAmazon [Bot], User avatarIncredible_Serious and 2 guests
