Pin retainer or set screw?
I am assembling the CVA kit 6371 and following the re-release World's kit instructions and I'm a bit confuzzed. It looks like they give you the option to use the pin retainer ring or use the 4-40 set screw. ---"Note: Remove pin retainer to prevent binding if using 4-40 set screw in CVA." So does one way work better than the other and why do they provide both!? I don't really understand why you wouldn't use them both. Anybody have experience here? Thanks!
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Pin retainer or set screw?
I run the setscrew and then heat shrink. Always have. I'm not sure how it would bind with the retainer and setscrew, since that's basically the same exact thing as the heat shrink method- but that's what the manual says
- Has thanked: 14 times
- Been thanked: 39 times
The setscrew can offset the pin in the assembly and cause binding.
I don't use the set screw. I use tiny drops of CA glue to lock the gap on the retainer clip 90 degrees to the cva pin.
- 1757 Views
Last post by Tamlok
- 1120 Views
Last post by HS-YZ250
- 1350 Views
Last post by adam lancia
- 934 Views
Last post by jamin
- 2099 Views
Last post by PBR Allstar
- 21 Replies
- 3184 Views
Last post by sundevil67
- 915 Views
Last post by Trailsnail
- 3002 Views
Last post by mytimac
