Worlds info?
- bearrickster
Worlds info?
So as the Losi guy I am, I just got a NIB Worlds kit I havent had a new RC10 in 20 years, is their any info or advice I should no before I build it? things I should door order to fix any short commings with the kit. mine has the upgraded trans parts it came with a new top shaft and gear box.
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Worlds info?
Tap the steering bellcranks with a 8-32 tap. I'd you don't it expands and even bearings will be a tight fit
Ream the suspension with a .127 if you have one
Grab a 6570 idler too, the stock idler was a source of friction. If you haven't seen my comparison video- I quickly show three variations; stock, USA case stock idler, and USA case 6570 idler. The difference is mind blowing
[youtube]3W1f9dyMFqI[/youtube]
- bearrickster
- RC104ever
Re: Worlds info?
Isn't the USA case part#6565? What about the top shaft?
- Chris
Lots of cars...so many cars
- bearrickster
Re: Worlds info?
I dont no my kit came with a loose B4 shaft and a RC10T trans case for some reason? the only difference I see in the cases are one has a plug to the top shaft one doesnt? I dont no RC10's so I am kinda lost. I built the front end tonight the new shocks are great but the steering bellcranks suck the bushings were so tight they wouldnt turn I replaced them with bearrings now smooth as glass.
Re: Worlds info?
gomachv wrote:Tap the steering bellcranks with a 8-32 tap. I'd you don't it expands and even bearings will be a tight fit
Is this the correct idler gear, also do you have part number for the case by any chance?
http://www.ebay.com/itm/Associated-Idler-Shaft-Gear-GT-Transmission-ASC6570-/361040704752?pt=Radio_Control_Parts_Accessories&hash=item540fb3f4f0
Re: Worlds info?
The case is a 6565 and the idler is a 6570. The idler gear that you linked from eBay is also the correct part. It will not work in the new China case, only the USA case...Which is the 6565
- bearrickster
Re: Worlds info?
Well I put mine together with all of the kit parts I used the new B4 upper shaft that they sent wit the kit ad the china case. As much as I hate to say it this is the smoothest rc car I have ever put together. all of the suspension and trans is silky smooth. the new shocks ae wonderful compared to anything AE has ever done before.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Re: Worlds info?
Great to hear Rick...now send it to me, your a Losi guy!
- bearrickster
Re: Worlds info?
no problem what are you going to send me to play with while your playing with mine?JK Racing wrote:Great to hear Rick...now send it to me, your a Losi guy!
- Seabass
- Business Member
- Been thanked: 12 times
Re: Worlds info?
Glad to here the car went together without any problems. I am glad you got the kit with the right parts to correct any issues that were found. Now we need pics of this thing.
Jake
Jake
- JK Racing
Re: Worlds info?
A Losi of course, it wont be new though...well, I do have a new build LXT
Re: Worlds info?
gomachv wrote:The case is a 6565 and the idler is a 6570. The idler gear that you linked from eBay is also the correct part. It will not work in the new China case, only the USA case...Which is the 6565
How do you know if it's a US or China case. I found this one"
http://www.amain.com/Team-Associated-Stealth-Transmission-Case/p386593
Re: Worlds info?
Thats it. The stock worlds case has a different part number (6564)
6565 is old moulding USA case
6564 is new "improved" China case
- 1494 Views
Last post by drbelleville
- 52 Replies
- 11617 Views
- 2089 Views
Last post by XLR8
- 55 Replies
- 12601 Views
- 69 Replies
- 14215 Views
Last post by pastimesteve
- 24 Replies
- 10655 Views
Last post by Garage Hack
- 1110 Views
Last post by lowrydesign
- 603 Views
Last post by kaiser
